When you need a headset that sounds great, feels great and looks great - look no further. Jabra Stone3 is simply a real standout among high-end headsets. Because great design goes a long way, the headset's light and curvy design will fit comfortably to the shape of your ear at all times. And when you're on-the-go, put the headset back in its sleek pocket-sized charging stone and it's ready to be taken with you anywhere.
Great design never shouts
When you need a headset that sounds great, feels great and looks great - look no further. Jabra Stone3 is simply a real standout among high-end headsets. Because great design goes a long way, the headset's light and curvy design will fit comfortably to the shape of your ear at all times. And when you're on-the-go, put the headset back in its sleek pocket-sized charging stone and it's ready to be taken with you anywhere. -
The wireless power to move
A pebble-shaped charging stone with the power to recharge in just 20 minutes is all it takes for Jabra Stone3 to be ready-to-use for another 10 hours. Get coffee, have a shower, read the newspaper and you're on. That's definition of always connected. -
Latest high-end technology
Jabra Stone3 comes with simple high-end features - manage calls with your voice, enjoy automatic volume control and have background noise made completely powerless over the sound quality of your calls. -
Quick and simple device pairing
You can instantly pair Jabra Stone3 with NFC enabled phones, tablets, and interactive tags. Just tap the headset to your device and you're ready to use it for calling and streaming in high fidelity quality.
- Jabra STONE3 - headset
- Product Type
- Headset - Bluetooth - wireless - NFC
- Recommended Use
- Portable electronics
- White
- Headphones Form Factor
- Over-the-ear mount - monaural
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 3.0 EDR
- Sound Output Mode
- Mono
- Impedance
- 16 Ohm
- Active Noise Canceling
- Microphone
- Built-in
- Controls
- Answer/end
- 1-year warranty
- Product Type
- 5.07 cm
- 2.47 cm
- 5.8 cm
- 7 g
- White
- Recommended Use
- Max Operating Distance
- 10 m
Audio Output
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 3.0 EDR
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Phonebook Access Profile (PBAP)
- Sound Output Mode
- Mono
- Active Noise Cancelling Technology
- Noise Blackout
- Impedance
- 16 Ohm
- Diaphragm
- 10 mm
Microphone
- Audio Input Details
- Omni-directional
Remote Control
- Controls
- Answer/end
Wireless Link
- Transmission Range
- 10 m
- Connector Type
- USB (5 pin Micro-USB Type B)
- Included Accessories
- 3 gel ear tips
- Cable Details
- USB cable
- GOST, IC, FCC, RoHS, KCC, TELEC, REACH, NCC, iDA
- Power Device
- Headset charging stand + power adapter - external
- Voltage Required
- AC 120/230 V (50 - 60 Hz)
- Battery
- Headset battery rechargeable
- Run Time (Up To)
- 2 hour(s)
- Standby Time
- 360 hours
- Limited warranty - 1 year
