Jabra Stone 3 - Black
Quicklinx: 8ZXFWS00 Mfr#: 100-99320000-61
When you need a headset that sounds great, feels great and looks great - look no further. Jabra Stone3 is simply a real standout among high-end headsets. Because great design goes a long way, the headset's light and curvy design will fit comfortably to the shape of your ear at all times. And when you're on-the-go, put the headset back in its sleek pocket-sized charging stone and it's ready to be taken with you anywhere.
  • Great design never shouts
  • The wireless power to move
    A pebble-shaped charging stone with the power to recharge in just 20 minutes is all it takes for Jabra Stone3 to be ready-to-use for another 10 hours. Get coffee, have a shower, read the newspaper and you're on. That's definition of always connected.
  • Latest high-end technology
    Jabra Stone3 comes with simple high-end features - manage calls with your voice, enjoy automatic volume control and have background noise made completely powerless over the sound quality of your calls.
  • Quick and simple device pairing
    You can instantly pair Jabra Stone3 with NFC enabled phones, tablets, and interactive tags. Just tap the headset to your device and you're ready to use it for calling and streaming in high fidelity quality.
Jabra STONE3 - headset
Headset - Bluetooth - wireless - NFC
Recommended Use
Portable electronics
Headphones Form Factor
Over-the-ear mount - monaural
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 3.0 EDR
Sound Output Mode
Mono
Active Noise Canceling
Microphone
Built-in
Controls
Answer/end
1-year warranty
5 cm
2.5 cm
5.8 cm
7 g
Recommended Use
Max Operating Distance
10 m
Audio Output
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 3.0 EDR
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Phonebook Access Profile (PBAP)
Sound Output Mode
Mono
Active Noise Cancelling Technology
Noise Blackout
Diaphragm
10 mm
Microphone
Audio Input Details
Omni-directional
Remote Control
Controls
Answer/end
Wireless Link
Transmission Range
10 m
Connector Type
USB (5 pin Micro-USB Type B)
3 gel ear tips
Cable Details
USB cable
Headset charging stand + power adapter - external
AC 120/230 V (50 - 60 Hz)
Headset battery rechargeable
Run Time (Up To)
2 hour(s)
Standby Time
120 hours
Limited warranty - 1 year
