Jabra STEEL Mono Headset
Quicklinx: CC9ZWS00 Mfr#: 100-97600000-60
Jabra STEEL is a Bluetooth headset specifically designed for rough working environments. The superior, state-of-the-art headset has been developed using Jabra's 145 years of R&D expertise in delivering audio innovation.
Following an extensive examination of the daily needs of trade professionals and craft workers, Jabra has created a highly durable headset to meet the specific needs of those with the toughest jobs, whether on-site in high winds, covered in dirt or under a kitchen sink. Jabra STEEL has been tested rigorously, by exposing it to high drops on to hard surfaces, testing it for water (and other liquid, such as paint) and dust ingress, as well as vibration, temperature and squeeze testing; all of which make it the right tool for rugged environments.
When you do touch work, you need tough equipment
Keep your smartphone in your pocket. Jabra STEEL is designed to resist dust, dirt, grime and water. It's even shock resistant, so it can take a drop from up high.
Introducing our toughest headset ever
Jabra STEEL is an industrial strength headset made for trade workers. Whether you are on-site and covered in dirt, or on a scaffold in high winds, Jabra Steel will keep you connected in any of the tough environments that you find yourself in.
Just Leave Your Glove on
Do you use gloves at work? Jabra Steel has extra-large buttons, sealed to resist water and dust, so you have easy access to Siri/Google Now, even with your gloves on. When you get a call, just say "answer" to pick it up.
  • Introducing our toughest headset ever
    Jabra Steel is an industrial strength headset made for trade workers. Whether you are on-site and covered in dirt, or on a scaffold in high winds, Jabra Steel will keep you connected in any of the tough environments that you find yourself in.
  • You have to have the right tool for the job
    When your work is dependent upon your hands, you need tough and reliable tools. Completing your work well is just as important as being ready for that call from your next client, regardless of where you are. Just like your tools, a tough headset is a must.
  • Just leave your gloves on
  • Exceptional comfort in a small tool
    The last thing you need in the middle of a conversation is a headset that falls out of your ear. Jabra Steel comes with ergonomic EarHooks that are made especially for trade workers to ensure that it is held safely in place all day, regardless of where you are or what you are doing. It is so comfortable you'll forget you are wearing it.
Jabra Steel - headset
Headset - Bluetooth - wireless - NFC
Headphones Form Factor
Ear-bud
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.1
Sound Output Mode
Mono
Impedance
16 Ohm
Microphone Operation Mode
Mono
5-year warranty
1.54 cm
7.15 cm
2.55 cm
10 g
Body Material
Polypropylene, silicone rubber, PC/ABS, thermoplastic elastomer (TPE)
Protection
Waterproof, shockproof, dust-resistant
Max Operating Distance
30 m
Audio Output
Ear-bud
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.1
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Phonebook Access Profile (PBAP)
Sound Output Mode
Mono
Impedance
16 Ohm
Simultaneously Connectable Devices Qty
8
Microphone
Mono
Frequency Response
300 - 3400 Hz
Signal-to-Noise Ratio
14 dB
Audio Input Details
Omni-directional
Wireless Link
Transmission Range
30 m
Connector Type
USB (5 pin Micro-USB Type B (power only))
2 earhooks, 3 pairs of EarGels, USB charger, 2 windsocks
Handset battery rechargeable
Run Time (Up To)
6 hour(s)
Standby Time
240 hours
Limited warranty - 5 years
