The Jabra Stealth UC lets you stay in the concentration zone for longer. With a Unified Communication-compatible dongle, Jabra Stealth UC ensures you can transfer from a conference call at your desk to a call on your softphone and/or mobile in one smooth step without changing headsets.
HD sound with noise reduction
Advanced Noise Blackout technology ensures clear, noise-free calls. Dual microphones reduce background noise, making you easy to hear. HD Voice* brings high-definition sound quality to both ends of the call. -
Superior comfort in a small design
Stealth delivers superior comfort in a small design. The weight of the headset is perfectly balanced. It's so discreet that you'll hardly notice you're wearing it. -
Dedicated voice control button
Leave your phone in your pocket. Activate Siri and Google Now by tapping a dedicated button directly on the headset. -
Stay connected with the nano sized Bluetooth adapter
With a compatible Bluetooth adapter, you can transfer calls from your softphone to your smartphone using the Jabra Stealth UC. Optimised for Microsoft® Lync™, fully UC compatible. -
HD SOUND WITH NOISE REDUCTION
SUPERIOR COMFORT IN A SMALL DESIGN
DEDICATED VOICE CONTROL BUTTON
STAY CONNECTED WITH THE NANO SIZED BLUETOOTH DONGLE
With a UC-compatible dongle, you can transfer calls from your softphone to your smartphone using the Jabra Stealth UC. Optimised for Microsoft® Lync™, fully UC compatible. -
Custom fit for optimal comfort
The smallest Jabra headset at 7.9 grams offers superior 'in ear' comfort for all-day wear and is so light and discreet you will hardly notice you are wearing it. Offering 6 ear gel types and 2 ear hook options, choose the perfect fit that's right for your ear. The breakthrough in product design is due to the MicroPOWER battery placed in the ear piece, not the boom-arm. Ensures optimum balance and comfort. -
EXTRA EARHOOKS & EARGELS FOR A PERFECT FIT
Comes with a set of eargels and earhooks that let you have the perfect fit. Try different combinations to find what works best for you. -
One headset for all your phones
Features multiple phone connectivity and full UC compatibility, so you can stay connected to all your phones using the same headset. Transfer calls from your VoIP softphone to your mobile phone and continue your call as you head out the door. Optimised for Microsoft Lync. -
Premium sound
Experience crystal-clear call quality wherever you are - even in noisy, windy environments. Dual microphones and DSP technology filter out unwanted background noise to give both ends of the conversation the best possible sound quality. -
SIMPLE PAIRING WITH NFC
Do you have an NFC-enabled phone? Pair it with your Jabra Stealth by simply tapping the two together. Quick and effortless. -
STREAM PODCASTS & GPS DIRECTIONS
Stream music, podcasts, and GPS directions wirelessly from your phone. -
Uncompromising Performance
The intuitive 'Power Nap' mode makes the headset power down when not in use to give you more talk-time. 10-days standby and 6 hours of talk-time with multi-phone and UC compatibility. -
Busylight
Jabra Busylight helps you to cope with the open office environment challenges and lets people clearly know you are on the phone. The indicator turns red when you are on a call and keeps you from being interrupted. -
Call Assist
Jabra's intelligent Call Assist lets you take a call without a click. Built-in motion sensor technology turns the headset on when you pick it up or touch it, and automatically answers the call when you place it on your ear. If you are already wearing the headset, you can accept or reject a call using just your voice. -
HiFi Audio Streaming
Jabra Bluetooth devices featuring A2DP allow you to stream music, podcasts, and even GPS directions in hi-fi quality to give you enhanced sound experience. -
Intelligent Volume Control
With Jabra intelligent volume control, you are now free from touching the volume control. The audio level adapts automatically to the interference noise around you, allowing you to hear what is being said wherever you are. -
Jabra Connect
The Jabra Connect app interacts actively with your headset and lets you customise your user experience to suit your preferences as well as control all your calls on multiple devices. -
MicroPOWER
A smaller more efficient rechargeable coin cell battery is placed in the ear piece, not the boom arm, offering perfect balance in a stylish unique small headset design. -
Multi-Device Connectivity
Multi-device connectivity technology lets you manage phone calls from several different devices such as deskphones, tablets, PCs and smartphones, with one single headset. You get greater flexibility and enhanced user experience. -
Power Nap Mode
With Jabra power nap mode, you can now leave your headset in the car or on your desk for days and still have it ready when you are. Your device automatically goes into sleeping mode when inactive. A great power management feature that gives you more talk time, less charging. -
Smartphone & Tablet Ready
Your Jabra device is designed with future-ready technology to be fully compatible with the latest smartphones and tablets on the market. -
Tap-To-Connect
Near Field Communication technology (NFC) makes it easy for your Jabra device to instantly connect and interact with phones, tablets, and interactive tags. It requires no more than a simple touch. Just tap the phone and the Jabra device together and you are ready to talk or stream your music. -
UC Plug-And-Play
Voice Controls
 - Jabra STEALTH UC - headset
- Product Type
 - Headset - Bluetooth - wireless - NFC
- Recommended Use
 - Portable electronics, computer
- Headphones Form Factor
 - In-ear
- Connectivity Technology
 - Wireless
- Wireless Technology
 - Bluetooth
- Bluetooth Version
 - Bluetooth 4.0 EDR
- Impedance
 - 32 Ohm
- Active Noise Canceling
- Microphone
 - Built-in
- Controls
 - Volume, on/off, answer/end
 - 2-year warranty
- Product Type
 - 1.54 cm
 - 6.52 cm
 - 2.42 cm
 - 7.9 g
- Recommended Use
- Max Operating Distance
 - 30 m
Audio Output
 - In-ear
 - Wireless
 - Bluetooth
- Bluetooth Version
 - Bluetooth 4.0 EDR
- Bluetooth Profiles
 - Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Active Noise Cancelling Technology
 - Noise Blackout
- Impedance
 - 32 Ohm
- Diaphragm
 - 11 mm
Microphone
- Audio Input Details
 - Omni-directional - 300 - 3400 Hz
Remote Control
- Controls
Wireless Link
- Transmission Range
 - 30 m
- Connector Type
 - USB (5 pin Micro-USB Type B (power only))
- Included Accessories
 - Car power adapter, USB dongle, 2 earhooks, 2 EarGels ear tips
 - Plug and Play, GOST, IC, FCC, RoHS, REACH
- Power Device
 - Power adapter - external
- Voltage Required
 - AC 120/230 V (50/60 Hz)
- Battery
 - Headset battery rechargeable
- Run Time (Up To)
 - 6 hour(s)
- Standby Time
 - 240 hours
- Recharge Time
 - 2 hour(s)
 - Limited warranty - 2 years
                        Jabra Link 370 USB BT Adapter, MS Teams | In Stock | £41.62 |
