Free your workout and push yourself harder with pumping Dolby sound. These ultra-chic wireless workout buds are built for premium sound and durability.
Free your workout with premium wireless sound
Exercise is about breaking free, so don't let wires hold you back. Powerful speakers deliver world-class music performance. Control music playback, volume, and take calls with a quick tap on the earbuds. -
When you need to pause, it does too
Catching your breath or catching up with a friend? Simply clip the earbuds together around your neck to save battery power. Pull them apart, and they're ready to run as soon as you are. -
Focus on your workout without distraction
Sport Rox Wireless earbuds are built to last with solid steel. They're sweat- and stormproof and built to US Military rain, shock, sand, and dust standards - so there's no excuse for missing a workout. An ultra-secure and comfortable fit with a selection of EarGels and EarWings lets you lock them in and focus on your workout. -
RICH DOLBY SOUND WITH THE JABRA SOUND APP
Get powerful wireless sound enhanced by Dolby . Exclusive Jabra Sound app adds extra depth and dimension to your music. Use it to create and share playlists and adjust equaliser settings. -
SIMPLE PAIRING WITH NFC
Do you have an NFC-enabled phone? Just tap Jabra Sport Rox Wireless and the phone together to pair them quickly and effortlessly.
- Jabra Sport Rox - earphones with mic
- Product Type
- Earphones - Bluetooth - wireless - NFC
- Recommended Use
- Portable electronics
- Headphones Form Factor
- In-ear
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Headphones Technology
- Dynamic
- Bluetooth Version
- Bluetooth 4.0 EDR
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 92 dB
- Impedance
- 16 Ohm
- Max Input Power
- 5 mW
- Microphone
- On-cable
- Controls
- Volume, answer/end, play/pause, next/previous track
- 1-year warranty
- Product Type
- 2 cm
- 1.6 cm
- 1.65 cm
- 19 g
- Recommended Use
- Protection
- Waterproof, shockproof, dust-resistant
- Max Operating Distance
- 10 m
Audio Output
- In-ear
- Dynamic
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 4.0 EDR
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Sound Output Mode
- Stereo
- 20 - 20000 Hz
- Max Input Power
- 5 mW
- Sensitivity
- 92 dB
- Impedance
- 16 Ohm
- Diaphragm
- 6 mm
Microphone
- On-cable
- 100 - 8000 Hz
Remote Control
- Controls
Wireless Link
- Transmission Range
- 10 m
- Connector Type
- USB (5 pin Micro-USB Type B (power only))
- Included Accessories
- Arm band, cable clip, 3 pairs of EarWings, 4 pairs of EarGels
- Cable Details
- Headphones cable - 55 cm , USB cable - 31 cm
- GOST, IC, FCC, RoHS, REACH, IP54, IP52
- Battery
- Headphone battery rechargeable
- Run Time (Up To)
- 5.5 hour(s)
- Standby Time
- 432 hours
- Recharge Time
- 2.5 hour(s)
- Limited warranty - 1 year
