The Jabra Sport-Corded is made to give you the comfort you need to be able to listen to your music or talk on your mobile phone while you walk, jog or run to your own beat. The Jabra Sport-Corded is ultra-light and easy to wear. With a choice of Ultimate Comfort Eargels and a flexible behind-the-ear fit, it stays firmly and comfortably in place. It's also tough. With military grade rain, dust and shock protection it is fit for any challenge, indoors or outdoors. For more freedom while you exercise, the Jabra Sport-Corded comes with an extension cable. It also comes with a carrying case, for added convenience.
With the Jabra Sport-Corded you get exceptional music and call sound quality and a wind-shielded microphone. A control box right on the cord allows you to control your music and calls with ease.
- Jabra Sport Corded - headset
- Product Type
- Headset - wired
- Recommended Use
- Portable electronics
- Headphones Form Factor
- Ear-bud - over-the-ear mount - binaural
- Connectivity Technology
- Wired
- Headphones Technology
- Dynamic
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 18 - 21000 Hz - Sensitivity 98 dB
- Impedance
- 32 Ohm
- Microphone
- On-cable
- Controls
- Volume, answer/end
- 1-year warranty
- Product Type
- Headset - wired
- 30 g
- Recommended Use
Audio Output
- Dynamic
- Wired
- Sound Output Mode
- Stereo
- 18 - 21000 Hz
- Sensitivity
- 98 dB
- Impedance
- 32 Ohm
- Diaphragm
- 13.5 mm
- In-Cord Volume Control
Microphone
- On-cable
- Sensitivity
- -42 dB
- Audio Input Details
- Omni-directional
Remote Control
- Player remote control
- Controls
- Connector Type
- Headset (mini-phone stereo 3.5 mm 4-pole)
Cable
- Plated Connector
- Gold
- Included Accessories
- Carrying case, cellular phone audio adapter, clothing clip, 3 pairs of ear tips, audio extension cable
- Cable Details
- Headset cable - 1.3 m
- MIL-STD 810G
- Limited warranty - 1 year
