Jabra Sport Coach Wireless Headphones
Quicklinx: BR8DWS00 Mfr#: 100-97500001-60
Exercise is about freedom, about pushing limits and enjoying doing it. Some people like to exercise while listening to music, some talk on the phone. With the Jabra Sport Bluetooth stereo headset it's easy to do both - and without the hassle of headset wires that slow you down. You simply stream music and calls via Bluetooth to it.
With the Jabra Sport you get exceptional music and call sound quality. It has A2DP, AM3D power bass audio enhancement and a wind-shielded microphone and virtual surround sound audio enhancements. It also has a built-in FM radio so you can tune in to your favorite station while you work out.
The Jabra Sport is ultra-light and easy to wear. With a choice of different ear gels and a flexible behind-the-ear fit, it stays firmly Eargels and comfortably in place. It's also tough. With military grade rain, dust and shock protection it is fit for any challenge, indoors or outdoors.
  • EASY PAIRING WITH NFC
    Do you have an NFC-enabled phone? Pair it with your Jabra Sport Coach by simply tapping the two together. Quick and effortless.
  • IMMERSIVE WIRELESS MUSIC POWERED BY DOLBY
    Don't compromise on the sound quality. Dolby sound enhancement brings out the true depth and clarity of your digital music, even when listening to YouTube tracks. All without wires getting in your way, allowing you to focus 100% on your work-out.
  • INTELLIGENT AUDIO COACHING
    Plan, track, and analyse your cross training or other indoor work-out. Choose from more than 40 exercises, from beginner to advanced. Get in-the-moment, personalised in-ear audio coaching as you work out. Use time or repetition-based training while being motivated by your favourite music.
  • SECURE & COMFORTABLE FIT
    Won't hurt your ears or fall out, thanks to its ergonomic design. Find the perfect fit with 3 sets of eargels. Weighs a mere 16 grams (0.56 oz), so you'll hardly notice you're wearing it.
  • SWEAT & WEATHER RESISTANT
    Built to US military standards (IP55), Jabra Sport Coach is sweat, shock, and weatherproof. It's crafted to withstand exercise under any conditions.
  • TRACKFIT MOTION SENSOR
    If you combine your cross training with running, the integrated TrackFit motion sensor will measure distance, pace, steps, cadence and calories burned. This unique motion sensor captures detailed activity and performance data for the Jabra Sport Life app, helping you train at the right intensity.
Jabra Sport Coach - earphones with mic
Earphones - Bluetooth - wireless - NFC
Recommended Use
Portable electronics
Blue
Headphones Form Factor
In-ear
Wireless
Wireless Technology
Bluetooth
Headphones Technology
Dynamic
Bluetooth Version
Bluetooth 4.0
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 94 dB
Impedance
16 Ohm
Max Input Power
5 mW
Microphone
On-cable
1-year warranty
2.1 cm
3.2 cm
1.8 cm
16 g
Blue
Recommended Use
Protection
Weatherproof, shockproof, sweat-resistant
Max Operating Distance
10 m
Audio Output
In-ear
Dynamic
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.0
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
Max Input Power
5 mW
Sensitivity
94 dB
Impedance
16 Ohm
Diaphragm
6 mm
Microphone
On-cable
Frequency Response
100 - 8000 Hz
Tracking
Sensors
Motion sensor
Wireless Link
Transmission Range
10 m
Connector Type
USB (5 pin Micro-USB Type B (power only))
Protective pouch, 2 cable clips, 3 pairs of EarWings, 4 pairs of EarGels
Cable Details
Headphones cable - 60 cm , USB cable - 31 cm
Headphone battery rechargeable
Run Time (Up To)
5.5 hour(s)
Standby Time
240 hours
Recharge Time
2 hour(s)
Limited warranty - 1 year
