Your basket is empty
Jabra Sport Coach Red
Quicklinx: CCB9WS00 Mfr#: 100-97500002-60
Exercise is about freedom, about pushing limits and enjoying doing it. Some people like to exercise while listening to music, some talk on the phone. With the Jabra Sport Bluetooth stereo headset it's easy to do both - and without the hassle of headset wires that slow you down. You simply stream music and calls via Bluetooth to it.
With the Jabra Sport you get exceptional music and call sound quality. It has A2DP, AM3D power bass audio enhancement and a wind-shielded microphone and virtual surround sound audio enhancements. It also has a built-in FM radio so you can tune in to your favorite station while you work out.
The Jabra Sport is ultra-light and easy to wear. With a choice of different ear gels and a flexible behind-the-ear fit, it stays firmly Eargels and comfortably in place. It's also tough. With military grade rain, dust and shock protection it is fit for any challenge, indoors or outdoors.
Jabra Sport Coach - earphones with mic
Earphones - Bluetooth - wireless - NFC
Recommended Use
Portable electronics
Red
Headphones Form Factor
In-ear
Wireless
Wireless Technology
Bluetooth
Headphones Technology
Dynamic
Bluetooth Version
Bluetooth 4.0
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 94 dB
Impedance
16 Ohm
Max Input Power
5 mW
Microphone
On-cable
1 year warranty
Earphones - Bluetooth - NFC
2.1 cm
3.2 cm
1.8 cm
16 g
Red
Recommended Use
Protection
Weatherproof, shockproof, sweat-resistant
Max Operating Distance
10 m
Headphones
In-ear
Dynamic
Wireless
Wireless Technology
Bluetooth
Available Microphone
Bluetooth Version
Bluetooth 4.0
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
Max Input Power
5 mW
Sensitivity
94 dB
Impedance
16 Ohm
Diaphragm
6 mm
Microphone
On-cable
Frequency Response
100 - 8000 Hz
Tracking
Sensors
Motion sensor
Wireless Link
Transmission Range
10 m
Connector Type
USB (5 pin Micro-USB Type B (power only))
Headphones cable - 60 cm , USB cable - 31 cm
Protective pouch, 2 cable clips, 3 pairs of EarWings, 4 pairs of EarGels
Headphone battery rechargeable
Run Time (Up To)
5.5 hour(s)
Standby Time
240 hours
Recharge Time
2 hour(s)
Limited warranty - 1 year
