Exercise is about freedom, about pushing limits and enjoying doing it. Some people like to exercise while listening to music, some talk on the phone. With the Jabra Sport Bluetooth stereo headset it's easy to do both - and without the hassle of headset wires that slow you down. You simply stream music and calls via Bluetooth to it.
With the Jabra Sport you get exceptional music and call sound quality. It has A2DP, AM3D power bass audio enhancement and a wind-shielded microphone and virtual surround sound audio enhancements. It also has a built-in FM radio so you can tune in to your favorite station while you work out.
The Jabra Sport is ultra-light and easy to wear. With a choice of different ear gels and a flexible behind-the-ear fit, it stays firmly Eargels and comfortably in place. It's also tough. With military grade rain, dust and shock protection it is fit for any challenge, indoors or outdoors.
EASY PAIRING WITH NFC
Do you have an NFC-enabled phone? Pair it with your Jabra Sport Coach by simply tapping the two together. Quick and effortless. -
IMMERSIVE WIRELESS MUSIC POWERED BY DOLBY
Don't compromise on the sound quality. Dolby sound enhancement brings out the true depth and clarity of your digital music, even when listening to YouTube tracks. All without wires getting in your way, allowing you to focus 100% on your work-out. -
INTELLIGENT AUDIO COACHING
Plan, track, and analyse your cross training or other indoor work-out. Choose from more than 40 exercises, from beginner to advanced. Get in-the-moment, personalised in-ear audio coaching as you work out. Use time or repetition-based training while being motivated by your favourite music. -
SECURE & COMFORTABLE FIT
Won't hurt your ears or fall out, thanks to its ergonomic design. Find the perfect fit with 3 sets of eargels. Weighs a mere 16 grams (0.56 oz), so you'll hardly notice you're wearing it. -
SWEAT & WEATHER RESISTANT
Built to US military standards (IP55), Jabra Sport Coach is sweat, shock, and weatherproof. It's crafted to withstand exercise under any conditions. -
TRACKFIT MOTION SENSOR
If you combine your cross training with running, the integrated TrackFit motion sensor will measure distance, pace, steps, cadence and calories burned. This unique motion sensor captures detailed activity and performance data for the Jabra Sport Life app, helping you train at the right intensity.
- Jabra Sport Coach - earphones with mic
- Product Type
- Earphones - Bluetooth - wireless - NFC
- Recommended Use
- Portable electronics
- Red
- Headphones Form Factor
- In-ear
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Headphones Technology
- Dynamic
- Bluetooth Version
- Bluetooth 4.0
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 94 dB
- Impedance
- 16 Ohm
- Max Input Power
- 5 mW
- Microphone
- On-cable
- 1-year warranty
- Product Type
- 2.1 cm
- 3.2 cm
- 1.8 cm
- 16 g
- Red
- Recommended Use
- Protection
- Weatherproof, shockproof, sweat-resistant
- Max Operating Distance
- 10 m
Audio Output
- In-ear
- Dynamic
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 4.0
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Sound Output Mode
- Stereo
- 20 - 20000 Hz
- Max Input Power
- 5 mW
- Sensitivity
- 94 dB
- Impedance
- 16 Ohm
- Diaphragm
- 6 mm
Microphone
- On-cable
- 100 - 8000 Hz
Tracking
- Sensors
- Motion sensor
Wireless Link
- Transmission Range
- 10 m
- Connector Type
- USB (5 pin Micro-USB Type B (power only))
- Included Accessories
- Protective pouch, 2 cable clips, 3 pairs of EarWings, 4 pairs of EarGels
- Cable Details
- Headphones cable - 60 cm , USB cable - 31 cm
- Battery
- Headphone battery rechargeable
- Run Time (Up To)
- 5.5 hour(s)
- Standby Time
- 240 hours
- Recharge Time
- 2 hour(s)
- Limited warranty - 1 year
