Hear and be heard when it matters
Hold completely natural conversations via speakerphone as both sides of the conversation are transmitted at the same time, allowing conversations to flow just as they do in person. -
Certified for Microsoft Teams
Built to fit in with the way the modern world works, the Microsoft Teams variant has a dedicated LED button that flashes for notifications. Tap to join meetings and use it to see when you have missed calls or voicemails. -
Works with all leading UC platforms
Versatile and easy to use and compatible with all leading Unified Communications platforms. Certified for use with UC, for an accessible, seamless connection experience and maximum flexibility when connecting with colleagues around the world. Enjoy a seamless meeting experience, whatever platform you're using. -
Plug-and-play for instant collaboration
Simply being able to plug-and-play to your laptop, smartphone or tablet, using either USB or Bluetooth, makes collaboration so much easier.
- Jabra SPEAK 750 MS - speakerphone
- Product Type
- Speakerphone - Bluetooth - wireless - USB
- Recommended Use
- Portable electronics, phone, computer, conference
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 4.2
- Sound Output Mode
- Mono
- Signal-To-Noise Ratio
- 70 dB
- Microphone Operation Mode
- Omni-directional
- Controls
- Mute, volume, answer/end
- 2-year warranty
- Product Type
- 301 g
- Recommended Use
- Max Operating Distance
- 30 m
Audio Output
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 4.2
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Sound Output Mode
- Mono
- 70 dB
- Acoustic echo cancelation
Microphone
- Form Factor
- Built-in
- Omni-directional
Remote Control
- Controls
- Included Accessories
- Jabra Link 370 USB Adapter, soft pouch
- Cable Details
- USB cable - 90 cm
- Plug and Play
- Battery
- Hands-free battery rechargeable
- Run Time (Up To)
- 10 hour(s)
- Recharge Time
- 3 hour(s)
- Limited warranty - 2 years
