Your basket is empty
Jabra SPEAK 510 USB/Bluetooth Speakerphone - MS Lync Varient
Quicklinx: 8G6RWS00 Mfr#: 7510-109
10 due in 5-7 days
£71.51 ex VAT
£85.81 inc VAT
Increase productivity and stay focused wherever you are with Jabra Speak 510, a portable speakerphone that gives you the power to literally turn any room into a conference room. You get outstanding sound quality and a plug-and-play solution that can connect to your PC, tablet or smartphone. Get empowered and join the conversation anytime, anywhere.
Jabra Speak 510 has a compact design and a travel case that make it well-suited for transport. Whether it's setting up a quick conference call in someone's office, or taking it along on the road, collaboration is made easy.
Jabra Speak 510 features a built-in, omni-directional microphone and a powerful speaker that enable 360-degree coverage. This gives you a professional conference call solution wherever you choose to place the call.
Jabra SPEAK 510 MS - speaker phone
Speaker phone - wireless, wired - Bluetooth
Wireless, wired - Bluetooth
Bluetooth Version
Bluetooth 2.0
Sound Output Mode
Mono
Microphone
Built-in
Microphone Operation Mode
Mono
Controls
Mute, volume, answer/end
Speaker phone - Bluetooth
Headphones
Bluetooth Version
Bluetooth 2.0
Sound Output Mode
Mono
Microphone
Mono
Audio Input Details
Omni-directional
Remote Control
Controls
Connector Type
USB (4 PIN USB Type A) , Headset (mini-phone 3.5 mm 4-pole)
USB cable
Rechargeable
Run Time (Up To)
15 hours
Resources
The following resources are available for the Jabra SPEAK 510 USB/Bluetooth Speakerphone - MS Lync Varient
Brand: Jabra
Price Range Ex VAT: 50 - 100
