Increase productivity and stay focused wherever you are with Jabra Speak, a range of portable speakerphones that give you the power to literally turn any room into a conference room. Regardless of your location and your timeline, you can now join the conversation anytime, anywhere.
SLIM AND COMPACT DESIGN
Get the perfect solution for audio conferencing on demand with a compact and lightweight design, an integrated USB cable management for quick set-up and a protective travel case.
PLUG-AND-PLAY SOLUTION
Plug your USB cable or connect via Bluetooth, and simply connect Jabra Speak to your PC, tablet or smartphone. That's it. You are ready to dial in.
OUTSTANDING SOUND QUALITY
To get crystal-clear and natural sounding calls that allow attendees to hear and speak clearly across any location.
UNLIMITED MOBILITY
Choose Jabra Speak 510 enhanced with Bluetooth to connect to any mobile device and get the freedom to communicate on your terms.
OPTIMAL USER EXPERIENCE
Benefit from full compatibility - including call control, with the leading UC/Softphone solutions and any Bluetooth enabled cell phone, smartphone or tablet.
Your portable UC conference room
Jabra SPEAK 410 is a speakerphone designed for office professionals with everyday need for audio conferencing. Its compact design and travel case make it easy to carry around, and the integrated cable management ensures quick set-up. It's the perfect solution for spontaneous conferencing and collaboration. -
Professional sound quality
Thanks to advanced Digital Signal Processing, Jabra SPEAK 410 provides crystal-clear audio with true wideband sound quality. The powerful speaker and built-in omni-directional microphone offer a 360-degree coverage allowing conference participants to hear and be heard. -
Advantages for individual use
Thanks to a 3.5 mm headset port and full-duplex audio, Jabra SPEAK 410 is ideal for one-to-one conversations and other functions such as e-learning and listening to media playback from the computer. You can switch easily to private-call mode to not disturb your colleagues in open office environments.
- Jabra SPEAK 410 - USB VoIP desktop hands-free
- Product Type
- USB VoIP desktop hands-free - wired - USB, 3.5 mm jack
- Compatibility
- Windows
- Recommended Use
- Computer - communication
- Additional Functions
- DSP, LED lights
- Connectivity Technology
- Wired
- Sound Output Mode
- Mono
- Audio Specifications
- Frequency Response 250 - 14000 Hz
- Microphone Operation Mode
- Omni-directional
- Controls
- Mute, volume, answer/end
- 2 years warranty
- Product Type
- USB VoIP desktop hands-free - USB, 3.5 mm jack
- Compatibility
- Windows
- DSP, LED lights
- 12 cm
- 12 cm
- 3.3 cm
- 180.3 g
- Recommended Use
Headphones
- Wired
- Sound Output Mode
- Mono
- 250 - 14000 Hz
- Diaphragm
- 50 mm
Microphone
- Form Factor
- Built-in
- Omni-directional
- 150 - 6500 Hz
- Audio Input Details
- Omni-directional - 150 - 6500 Hz
Remote Control
- Controls
- Connector Type
- USB 2.0 (4 PIN USB Type A) , Headset (mini-phone 3.5mm)
Cable
- Cable Length
- 90 cm
- Cables Included
- USB cable - 90 cm
- Included Accessories
- Carrying pouch
- Plug and Play, FCC, RoHS, KCC, REACH, EAC
- Limited warranty - 2 years
- Shipping Width
- 13.25 cm
- Shipping Depth
- 14.3 cm
- Shipping Height
- 4.55 cm
Jabra Headset Cord for Speak 410/510, Jack 3.5 mm straight to QD | In Stock | £8.81 |
Jabra USB-A to USB-C Adapter | In Stock | £7.73 |
