Jabra Speak 410 USB Speaker MS
Quicklinx: 7C6SWS00 Mfr#: 7410-109
Recommended Use: Computer
Connectivity: Wired
Earcover : [N/A]
More than 50 in stock
£61.27 ex VAT
£73.52 inc VAT
Increase productivity and stay focused wherever you are with Jabra Speak, a range of portable speakerphones that give you the power to literally turn any room into a conference room. Regardless of your location and your timeline, you can now join the conversation anytime, anywhere.
SLIM AND COMPACT DESIGN
Get the perfect solution for audio conferencing on demand with a compact and lightweight design, an integrated USB cable management for quick set-up and a protective travel case.
PLUG-AND-PLAY SOLUTION
Plug your USB cable or connect via Bluetooth, and simply connect Jabra Speak to your PC, tablet or smartphone. That's it. You are ready to dial in.
OUTSTANDING SOUND QUALITY
To get crystal-clear and natural sounding calls that allow attendees to hear and speak clearly across any location.
UNLIMITED MOBILITY
Choose Jabra Speak 510 enhanced with Bluetooth to connect to any mobile device and get the freedom to communicate on your terms.
OPTIMAL USER EXPERIENCE
Benefit from full compatibility - including call control, with the leading UC/Softphone solutions and any Bluetooth enabled cell phone, smartphone or tablet.
  • Your portable UC conference room
    Jabra SPEAK 410 is a speakerphone designed for office professionals with everyday need for audio conferencing. Its compact design and travel case make it easy to carry around, and the integrated cable management ensures quick set-up. It's the perfect solution for spontaneous conferencing and collaboration.
  • Easy set up and handling
    Jabra SPEAK 410 MS is optimized for seamless integration with Microsoft Lync. Simply connect Jabra SPEAK 410 MS to your computer and you are ready to make your first call. The unique and intuitive on-device call controls allow you to adjust the volume, mute and even answer or end a call. The external ringer ensures that you never miss a call.
  • Professional sound quality
    Thanks to advanced Digital Signal Processing (DSP), Jabra SPEAK 410 provides crystal-clear audio with true wideband sound quality. The powerful speaker and built-in omni-directional microphone offer a 360-degree coverage allowing conference participants to hear and be heard.
  • Advantages for individual use
    Thanks to a 3.5 mm headset port and full-duplex audio, Jabra SPEAK 410 is ideal for one-to-one conversations and other functions such as e-learning and listening to media playback from the computer. You can switch easily to private-call mode to not disturb your colleagues in open office environments.
Jabra SPEAK 410 MS - VoIP desktop speakerphone
VoIP desktop speakerphone - wired - USB
Compatibility
Windows
Recommended Use
Computer - communication
Additional Functions
DSP, LED lights
Wired
Sound Output Mode
Mono
Audio Specifications
Frequency Response 250 - 14000 Hz
Microphone Operation Mode
Omni-directional
Controls
Mute, volume, answer/end
Software Certification
Certified for Skype for Business
Compatibility
Windows
DSP, LED lights
12 cm
12 cm
3.3 cm
180.3 g
Recommended Use
Audio Output
Wired
Sound Output Mode
Mono
Frequency Response
250 - 14000 Hz
Diaphragm
50 mm
Microphone
Built-in
Omni-directional
Frequency Response
150 - 6500 Hz
Audio Input Details
Omni-directional - 150 - 6500 Hz
Remote Control
Controls
Connector Type
USB 2.0 (4 PIN USB Type A)
Cable
Cable Length
90 cm
Carrying pouch
Cable Details
USB cable - 90 cm
Plug and Play, FCC, RoHS, KCC, REACH, EAC
Shipping Width
13.25 cm
Shipping Depth
14.3 cm
Shipping Height
4.55 cm
7C6S Jabra Secure Mount For Speak 410/510 In Stock £8.53
7C6S Jabra USB-A to USB-C Adapter In Stock £7.75
Resources
The following resources are available for the Jabra Speak 410 USB Speaker MS
Connectivity: Wired
Earcover : [N/A]
Brand: Jabra
Price Range Ex VAT: 50 - 100
