Unplugged and Uncompromised.
Unleash your music with rich, full-spectrum Dolby® sound. Built with solid steel and a secure fit, Jabra Rox Wireless is for music gurus who are ready for action.
Go wireless
Give up the wires without giving up great sound. Rox Wireless lets you control your playlists and calls straight from in-line controls so you can keep your tunes going in high-definition Dolby® sound and your phone in your pocket.
Uncompromised wireless sound
Rox Wireless' design is based on the same in-ear monitors used by professional musicians to bring full sound and strong bass. And when you need that something extra, Jabra's exclusive Sound App* player with Dolby pumps out full-spectrum sound.
Travels well
Rox Wireless is protected against dust and water with solid steel that takes the rap when you're at your most active. Rox Wireless has exclusive power-saving magnets - when you're not using the earbuds, simply clip them together around your neck and the magnets will activate the power-saving mode.
Small & lightweight
Revel in your music and chat for longer in total comfort. Rox Wireless is small and lightweight with ColorCore EarGels™ designed for full sound and perfect fit. And when you're ultra-active, you can use optional EarWings™ to lock them in place.
Exclusive Jabra Sound App
Play your tunes and stream YouTube content in high-definition Dolby sound. Create playlists, share music and adjust the graphic equalizer for an extra personalized listening experience.
*Jabra Sound App with Dolby® sound enhancement is included exclusively as a free download for Jabra Revo Wireless, Jabra Revo, Jabra Rox Wireless, Jabra Vox, 2nd generation Jabra Solemates and Jabra Solemate Max.
Dolby and the double-D symbol are registered trademarks of Dolby Laboratories.
Battery-saving power magnets
When you need to pause, Jabra Rox does too. Once you're finished using the earbuds, simply snap them together around your neck using exclusive power-saving magnets. -
Immersive sound with wireless controls
Rox Wireless delivers high-definition sound with powerful bass. Leave your phone in your pocket - control your music and calls directly from the earbuds. -
Life proof: weather & dust resistant
Rox Wireless is protected against dust and water with its solid steel construction. It keeps on playing, no matter where you go. -
BATTERY-SAVING POWER MAGNETS
LIFEPROOF: WEATHER & DUST RESISTANT
- Jabra Rox Wireless - headset
- Accessories
- What's in the box?: Eargel Pack, Protective Bag
- App
- App Included: Jabra Sound
- The Jabra Sound App is the music player that adds full Dolby® sound to music – your playlists as well as your YouTube streaming content
- Connectivity
- Wireless Technology: Bluetooth
- Supports Bluetooth™ for wireless connectivity
- Bluetooth version: 4.0
- Supports Bluetooth® version 4.0
- AVRCP: Yes
- You can control your music from this device when it's streaming from another device, such as your mobile phone
- Auto Pairing: Yes
- With Auto Pairing, a device pairs automatically with Bluetooth® devices supporting this feature
- NFC Near Field Communications - Perimeter Pairing: Yes
- Near Field Communications (NFC) or Perimeter Pairing is an easy pairing functionality that connects two devices that are in close proximity to each other.
- Music: Yes
- Device can play music from a source, such as a Smartphone, Bluetooth enabled laptop, tablet, or MP3 player
- Speakers
- Frequency Response: Hifi
- Speakers with a hifi frequency sound produce a sound range well suited for realistic sound reproduction, e.g. Music
- Digital Signal Processing: Yes
- Digital Signal Processing (DSP) is a technology that digitally optimizes your voice and music and suppresses echoes
- Microphone
- Microphone Type: Omni Directional/noise filter
- Enhances call clarity by eliminating background noise from the office.
- Microphone Sensitivity: Standard (E-STD)
- Standard (STD) variation microphone sensitivity is comparable to a normal telephone receiver and is used in most telephone devices.
- Mute function: Yes
- Mute gives you the option to mute/unmute the microphone directly on the device
- Battery & Power
- Talk Time: Up to 5.5 hours
- Talk Time is the maximum time you can talk before a device runs out of power
- Standby Time: Up to 432 hours
- Standby Time is the maximum time a device can remain powered on
- Music Play Time: 6 hour
- Music Play Time is the maximum time you can play music before a device runs out of power
- USB Charging: Yes
- USB Charging enables a device to be charged via a USB cable
- Design
- Wearing Style: In the ear
- In the ear devices are worn in the ear
- Weight: 0.67 oz
- How much the headset weighs (in US ounces)
- Ear Cushion Type:
- Large (L) sized ear gels
- Medium (M) sized ear gels
- Small (S) sized ear gels
- Dimensions: H 0.65 x W 0.79 x D 0.63
- Product dimensions, in inches
- Dimensions: H 1.7 x W 2 x D 1.6
- Product dimensions, in centimeters
