Jabra REVO Wireless Stereo On-Ear Headphones - Black
Quicklinx: 8ZXLWS00 Mfr#: 100-96700000-60
Total wireless freedom.
No wires doesn't mean compromised sound quality. With Revo Wireless headphones, it means freedom of movement and massive sound that doesn't skip a beat. Turntable Touch Control allows you to easily play, skip or pause your music and manage calls. Hear and be heard with clear calls, tap to pair with NFC and keep your tunes going with long playback.
Massive sound.
We partnered with Dolby® to bring you powerful, mobile sound enhanced by Dolby Digital Plus*. With Jabra's exclusive Sound App, Dolby Digital Plus provides rich, full-spectrum sound that brings your device to life and adds extra depth and dimension to your music.
Ultimate durability. Designed to be used and abused, Revo Wireless is solidly built with an aluminum frame, steel hinges, and a shatterproof headband for extreme flexibility. Drop, bend and fold-tested to the max to ensure it can take whatever life has in store.
Comfort & ease of use.
Hard to the core and soft to the touch - Revo Wireless headphones are super comfortable with a padded headband and plush, memory foam ear cups. It features a foldable design for quick, compact storage and comes with a detachable cord and USB charging for convenience.
Exclusive Jabra Sound App.
Get an enhanced music experience with the Jabra Sound App - a music player that gives you the full Dolby Digital Plus sound and more. Use the App to create and browse through playlists, share music and adjust the graphic equalizer so you can play your tracks as you want to hear them.
*Jabra Sound App with Dolby® Digital Plus sound enhancement is included exclusively as a free download for Jabra Revo Wireless, Jabra Revo, Jabra Vox, 2nd generation Jabra Solemates and Jabra Solemate Max.
Dolby and the double-D symbol are registered trademarks of Dolby Laboratories.
  • COMFORT ON THE MOVE
    Super comfortable, with a padded headband and plush, memory foam ear cups. After you're finished, fold it up for quick, compact storage.
  • LIFEPROOF
    Solidly built with an aluminium frame, steel hinges, and a shatterproof headband. Drop-, bend- and fold-tested to ensure it can take whatever life has in store.
  • RICH DOLBY SOUND
    Get powerful wireless sound enhanced by Dolby . Exclusive Jabra Sound app adds extra depth and dimension to your music.
  • SIMPLE PAIRING WITH NFC
    Do you have an NFC-enabled phone? Pair it with Revo Wireless by simply tapping the two together. Quick and effortless.
  • WIRED OPTION
    Out of battery or can't connect wirelessly? Simply use the optional 3.5 mm or USB cables.
  • WIRELESS TOUCH CONTROL
    Manage your calls and music with intuitive Turntable Touch Control. Play, pause, and skip tracks by simply swiping or tapping the ear cups.
Jabra Revo Wireless - headphones with mic
Headphones - Bluetooth - wireless - NFC
Recommended Use
Portable electronics, computer
Headphones Form Factor
Full size binaural
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 3.0
Sound Output Mode
Stereo
Microphone
Built-in
Controls
Volume, answer/end, play/pause
16 cm
7.3 cm
17.8 cm
240 g
Recommended Use
Audio Output
Full size binaural
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 3.0
Sound Output Mode
Stereo
Microphone
Audio Input Details
Omni-directional
Remote Control
Controls
Connector Type
USB
Carrying case, audio cable, USB power cable
Headphone battery rechargeable
Run Time (Up To)
12 hour(s)
Standby Time
240 hours
