Introducing the world's first sports headphones with automatic VO2 Max measurement
Superior quality wireless sound & calls
Enhanced wireless sound for up to 5 hours of play time.
Superior sound - now with passive noise cancellation and enhanced bass
Get rid of the surrounding noise at the gym and focus on your performance! With the new COMPLY™ foam ear tips you will get superior sound quality, passive noise cancellation and enhanced bass. Jabra Sport Pulse will make sure that your favourite playlist sounds better than ever and will maximise your musical motivation.
Built-in heart rate monitor
Understanding your heart rate is as simple as putting on your headphones. The built-in heart rate monitoring technology measures your heart rate via your inner ear. Jabra Sport Pulse delivers clinical-grade accuracy and ensures that you are always training at the right intensity level to improve your performance.
In-ear heart rate monitor
Gold standard accuracy ensures you're always working out in the right zone.
Jabra's Sport Life™ app
Get the most out of your Sport Pulse earbuds with Jabra's fitness app, which ensures you're always training in the right heart rate zone.
Plan, monitor and evaluate your performance. In-ear coaching gives you real-time feedback to help you optimise each session.
What's in the box?
- Jabra Sport Pulse Wireless Headphones
- Protective Bag
- Comply Foam Tips (3 Sizes)
- Jabra EarGels (3 Sizes)
- Rubber USB Cable
BUILT FOR INTENSE WORKOUTS
Built to US military rain, shock, sand and dust standards. "Quite simply, Pulse has the best fitting sports earbuds we've ever worn. -
FREE YOUR WORKOUT WITH IMMERSIVE WIRELESS SOUND
Exercise is about breaking free, so why let wires hold you back? Get fired up by your favourite songs with immersive sound. Control music playback, volume and take calls with a quick tap on the earbuds. -
IN-EAR HEART RATE MONITOR
Understanding your heart rate is now as simple as putting on your headphones. Jabra’s next generation of heart rate monitoring technology measures your heart rate via your inner ear. They’re the only earbuds proven to deliver clinical-grade accuracy. Sport Pulse ensures you always train at the right intensity level to improve your performance.
- Jabra Sport Pulse Wireless - headset
- Product Type
- Headset - Bluetooth - wireless - NFC
- Recommended Use
- Portable electronics
- Headphones Form Factor
- In-ear
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Headphones Technology
- Dynamic
- Bluetooth Version
- Bluetooth 4.0 EDR
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 94 dB
- Impedance
- 16 Ohm
- Max Input Power
- 5 mW
- Microphone
- On-cable
- Controls
- Volume, answer/end
- 1-year warranty
- Product Type
- 2.1 cm
- 3.2 cm
- 1.8 cm
- 16 g
- Recommended Use
- Max Operating Distance
- 10 m
Audio Output
- In-ear
- Dynamic
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 4.0 EDR
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Sound Output Mode
- Stereo
- 20 - 20000 Hz
- Max Input Power
- 5 mW
- Sensitivity
- 94 dB
- Impedance
- 16 Ohm
- Diaphragm
- 6 mm
Microphone
- On-cable
- Sensitivity
- -14 dB
- 100 - 8000 Hz
- Audio Input Details
- Omni-directional - 100 - 8000 Hz
Remote Control
- Controls
Tracking
- Sensors
- Heart rate
Wireless Link
- Transmission Range
- 10 m
- Connector Type
- USB (5 pin Micro-USB Type B (power only))
- Included Accessories
- Protective pouch, cable clip, 3 pairs of EarWings, 4 pairs of EarGels
- Cable Details
- USB cable
- GOST, IC, FCC, RoHS, REACH, IP55
- Battery
- Headset battery rechargeable
- Run Time (Up To)
- 5 hour(s)
- Standby Time
- 240 hours
- Recharge Time
- 2 hour(s)
- Limited warranty - 1 year
