Product
Brand
Jabra Pulse Wireless Headphones
Quicklinx: BR8BWS00 Mfr#: 100-96100000-60
Introducing the world's first sports headphones with automatic VO2 Max measurement
Superior quality wireless sound & calls
Enhanced wireless sound for up to 5 hours of play time.
Superior sound - now with passive noise cancellation and enhanced bass
Get rid of the surrounding noise at the gym and focus on your performance! With the new COMPLY™ foam ear tips you will get superior sound quality, passive noise cancellation and enhanced bass. Jabra Sport Pulse will make sure that your favourite playlist sounds better than ever and will maximise your musical motivation.
Built-in heart rate monitor
Understanding your heart rate is as simple as putting on your headphones. The built-in heart rate monitoring technology measures your heart rate via your inner ear. Jabra Sport Pulse delivers clinical-grade accuracy and ensures that you are always training at the right intensity level to improve your performance.
In-ear heart rate monitor
Gold standard accuracy ensures you're always working out in the right zone.
Jabra's Sport Life™ app
Get the most out of your Sport Pulse earbuds with Jabra's fitness app, which ensures you're always training in the right heart rate zone.
Plan, monitor and evaluate your performance. In-ear coaching gives you real-time feedback to help you optimise each session.
What's in the box?
  • Jabra Sport Pulse Wireless Headphones
  • Protective Bag
  • Comply Foam Tips (3 Sizes)
  • Jabra EarGels (3 Sizes)
  • Rubber USB Cable
Jabra Sport Pulse Wireless - headset
Headset - Bluetooth - wireless - NFC
Recommended Use
Portable electronics
Headphones Form Factor
In-ear
Wireless
Wireless Technology
Bluetooth
Headphones Technology
Dynamic
Bluetooth Version
Bluetooth 4.0 EDR
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 94 dB
Impedance
16 Ohm
Max Input Power
5 mW
Microphone
On-cable
Controls
Volume, answer/end
1 year warranty
Headset - Bluetooth - NFC
2.1 cm
3.2 cm
1.8 cm
16 g
Recommended Use
Max Operating Distance
10 m
Headphones
In-ear
Dynamic
Wireless
Wireless Technology
Bluetooth
Available Microphone
Bluetooth Version
Bluetooth 4.0 EDR
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
Max Input Power
5 mW
Sensitivity
94 dB
Impedance
16 Ohm
Diaphragm
6 mm
Microphone
On-cable
Sensitivity
-14 dB
Frequency Response
100 - 8000 Hz
Audio Input Details
Omni-directional - 100 - 8000 Hz
Remote Control
Controls
Volume, answer/end
Tracking
Sensors
Heart rate
Wireless Link
Transmission Range
10 m
Connector Type
USB (5 pin Micro-USB Type B (power only))
USB cable
Protective pouch, cable clip, 3 pairs of EarWings, 4 pairs of EarGels
GOST, IC, FCC, RoHS, REACH, IP55
Headset battery rechargeable
Run Time (Up To)
5 hour(s)
Standby Time
240 hours
Recharge Time
2 hour(s)
Limited warranty - 1 year
