Jabra PRO 9470 Mono Triple Connectivity Wireless Headset with Touchscreen
Quicklinx: 6JK2WS00 Mfr#: 9470-26-904-102
Today's business cards often feature different numbers for desk, mobile and softphone. The result? You find yourself grabbing your mobile just as the caller gives up and tries the desk phone instead! Designed with busy managers and specialists in mind, Jabra PRO 9470 can save you a lot of hassle. Thanks to Multiuse technology, all your phone calls come to the same headset. Just tap the talk button and start talking.The three devices - desk, mobile and softphone - are united by a stylish touch screen base. The base connects to your headset via DECT - a technology characterized by its reliable, long range capabilities - offering a wireless range of up to 150m. Equipped with a SmartSetup wizard, the touch screen helps you connect phones and choose preferences to get started. Once you're up and running, it's colorful icons and intuitive menu system make call-handling a breeze.Several state-of-the-art sound technologies enable the Jabra PRO 9470 to deliver unrivaled call clarity and safety. A dual microphone Noise Blackout system with advanced Digital Signal Processing practically eliminates all background noise, so your voice can always be heard clearly. Wideband quality ensures that the sound you hear is crystal clear, while SafeTone technology protects your hearing.
  • One headset for all phones
    Take every call on the same headset. Connects to your desk phone, mobile and softphone - all at the same time. Manage multiple calls through an industry-first, user-friendly touch-screen or touchpad. Also comes with a SmartSetup wizard that guides you through the connection process.
  • Outstanding sound quality
    If you talk and listen for a living, clear conversations can make or break a deal. Get best-in-class noise-cancellation and acoustic protection. Your calls will sound great – even in the noisiest of offices. Noise Blackout : Ear cushions and microphone are specially designed to eliminate background noise. Digital Signal Processing and HD Voice make your calls more intelligible and lifelike. SafeTone technology automatically counters unexpected spikes in volume and protects your ears.
  • True wireless freedom
    Wireless DECT technology allows you to roam up to 150 metres away from your desk without dropping the call. Answer and end calls remotely while multitasking around the office. With up to 10 hours of battery life, you won't need to worry about running out of charge.
  • DECT security compliant
    Compliant with the latest security requirements of the DECT standard, designed to safeguard against eavesdropping. The Jabra-patented headset-to-base pairing process avoids risky pairing over the air to protect your conversations.
Jabra PRO 9470 - headset
Headset - DECT - wireless
Recommended Use
Portable electronics, phone, computer
Hong Kong, Singapore, United Kingdom
Headphones Form Factor
Convertible
Wireless
Wireless Technology
DECT
Sound Output Mode
Mono
Audio Specifications
Frequency Response 150 - 6800 Hz
Active Noise Canceling
Microphone
Boom
Controls
Mute, volume, tone, answer/end
28 g
Recommended Use
Max Operating Distance
150 m
Headphones
Convertible
Wireless
Wireless Technology
DECT
Sound Output Mode
Mono
Active Noise Cancelling Technology
Noise Blackout
Frequency Response
150 - 6800 Hz
Microphone
Boom
Remote Control
Controls
Wireless Link
Transmission Range
150 m
USB cable , Phone cable
Neck strap, headband, power adapter, base station, headset charging cradle, earhook
EN 60950, UL 60950, FCC, IEC 60950-1
Headset battery rechargeable - Lithium Ion
Included Qty
1
315 mAh
Run Time (Up To)
8 hour(s)
Standby Time
46 hours
6JK2 Jabra DHSG Cable In Stock £20.72
6JK2 Jabra EHS Cable For Polycom IP Phones In Stock £24.81
6JK2 Jabra Electronic Hook Switch headset Adaptor In Stock £31.11
6JK2 Jabra PRO 900/9400 Neckband In Stock £12.77
6JK2 Jabra PRO 900 and 9400 Series Earhook In Stock £6.29
6JK2 Jabra PRO 9400 Series Ear Pads - Pack of 2 In Stock £6.48
6JK2 Jabra PRO 9470 Mono Spare Headset (without wearing style) In Stock £97.78
6JK2 Jabra Electronic Hook Switch Cable In Stock £24.81
6JK2 Jabra LINK EHS-Adapter For Cisco 6945 78xx/79xx/88xx Desk Phones In Stock £24.81
Resources
The following resources are available for the Jabra PRO 9470 Mono Triple Connectivity Wireless Headset with Touchscreen
