Jabra PRO 9465 Duo Flex-boom NC Headset
Quicklinx: 84M4WS00 Mfr#: 9465-29-804-102
Recommended Use: Computer, Phone, Phone, Portable electronics
Connectivity: Wireless
Earcover : Binaural
£228.72 ex VAT
£274.46 inc VAT
Do you battle against the background noise at work? If you can't get the peace and quiet you need to make important calls, try the Jabra PRO 9465 headset. A series of noise canceling, sound enhancing technologies make this headset ideal for office personnel and specialists working in shared spaces. And thanks to triple connectivity, you no longer have to think about which phone is ringing. Whether a caller is trying to get through on your desk, soft or mobile phone, the call will always come to the same headset. You just tap the talk button and answer.
  • One headset for all phones
    Take every call on the same headset. Connects to your desk phone, mobile and softphone - all at the same time. Manage multiple calls through an industry-first, user-friendly touch-screen or touchpad. Also comes with a SmartSetup wizard that guides you through the connection process.
  • Outstanding sound quality
    If you talk and listen for a living, clear conversations can make or break a deal. Get best-in-class noise-cancellation and acoustic protection. Your calls will sound great – even in the noisiest of offices. Noise Blackout : Ear cushions and microphone are specially designed to eliminate background noise. Digital Signal Processing and HD Voice make your calls more intelligible and lifelike. SafeTone technology automatically counters unexpected spikes in volume and protects your ears.
  • True wireless freedom
    Wireless DECT technology allows you to roam up to 150 metres away from your desk without dropping the call. Answer and end calls remotely while multitasking around the office. With up to 10 hours of battery life, you won't need to worry about running out of charge.
  • DECT security compliant
    Compliant with the latest security requirements of the DECT standard, designed to safeguard against eavesdropping. The Jabra-patented headset-to-base pairing process avoids risky pairing over the air to protect your conversations.
  • 10-Hour Battery Life
    Multi-device connectivity technology lets you manage phone calls from several different devices such as deskphones, tablets, PCs and smartphones, with one single headset. You get greater flexibility and enhanced user experience.
  • Smartphone & Tablet Ready
    Your Jabra device is designed with future-ready technology to be fully compatible with the latest smartphones and tablets on the market.
Jabra PRO 9465 Duo - headset
Headset - DECT - wireless
Recommended Use
Portable electronics, phone, computer
United Kingdom
Headphones Form Factor
On-ear
Wireless
Wireless Technology
DECT
Sound Output Mode
Mono
Audio Specifications
Frequency Response 150 - 6800 Hz
Active Noise Canceling
Microphone
Boom
Controls
Mute, volume, answer/end
70 g
Recommended Use
Max Operating Distance
150 m
United Kingdom
Headphones
On-ear
Wireless
Wireless Technology
DECT
Sound Output Mode
Mono
Active Noise Cancelling Technology
Noise Blackout
Frequency Response
150 - 6800 Hz
Microphone
Boom
Remote Control
Controls
Wireless Link
Transmission Range
150 m
USB cable , Phone cable
Base station, headset charging cradle
EN 60950, UL 60950, IEC 60950-1
Power adapter - external
Headset battery rechargeable
Included Qty
1
Run Time (Up To)
11 hour(s)
84M4 Jabra DHSG Cable In Stock £20.72
84M4 Jabra EHS Cable For Polycom IP Phones In Stock £24.81
84M4 Jabra Electronic Hook Switch headset Adaptor In Stock £31.11
84M4 Jabra PRO 9400 Series Ear Pads - Pack of 2 In Stock £6.48
84M4 Jabra PRO 9460 Duo Spare Headset (Top Only) In Stock £110.14
84M4 Jabra LINK Electronic Hook Switch Adapter Cable In Stock £31.11
84M4 Jabra LINK EHS-Adapter For Cisco 6945 78xx/79xx/88xx Desk Phones In Stock £24.81
Recommended Use: Phone
Recommended Use: Portable electronics
Earcover : Binaural
Brand: Jabra
Price Range Ex VAT: 150 - 300
