Your basket is empty
Jabra PRO 9465 Duo Flex-boom NC - European Model
Quicklinx: B6XQWS00 Mfr#: 9465-29-804-101
Recommended Use: Portable electronics
Connectivity: Wireless
£229.22 ex VAT
£275.06 inc VAT
Do you battle against the background noise at work? If you can't get the peace and quiet you need to make important calls, try the Jabra PRO 9465 headset. A series of noise canceling, sound enhancing technologies make this headset ideal for office personnel and specialists working in shared spaces. And thanks to triple connectivity, you no longer have to think about which phone is ringing. Whether a caller is trying to get through on your desk, soft or mobile phone, the call will always come to the same headset. You just tap the talk button and answer.
Jabra PRO 9465 DUO - headset
Headset - wireless - DECT
Recommended Use
Portable electronics, phone, computer
Headphones Form Factor
On-ear
Wireless - DECT
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 150 - 6800 Hz
Microphone
Boom
Controls
Mute, volume, answer/end
Headset - DECT
70 g
Recommended Use
Headphones
Supraaural
Wireless - DECT
Available Microphone
Sound Output Mode
Stereo
Frequency Response
150 - 6800 Hz
Microphone
Boom
Remote Control
Controls
Wireless Link
Transmission Range
150 m
USB cable , Phone cable
Base station, headset charging cradle
EN 60950, UL 60950, IEC 60950-1
Power adapter - external
Headset battery rechargeable
Included Qty
1
Run Time (Up To)
11 hour(s)
Brand: Jabra
Price Range Ex VAT: 150 - 300
