Jabra PRO 9460 Spare Headset
Quicklinx: 7C5GWS00 Mfr#: 14401-05
Recommended Use: Computer, Phone, Phone, Portable electronics
Connectivity: Wireless
Earcover : Monaural
More than 50 in stock
£97.78 ex VAT
£117.33 inc VAT
With Jabra PRO 9460 headset, office staff can answer calls made to either of their phones, even while away from their desks. Specially designed for open plan working environments, the model is fitted with a flex boom for optimum voice pick-up. Jabra PRO 9460 is a single-ear headset that can be worn hooked over the ear, or on a head or neckband.
The device is united by a stylish touch screen base. The base connects to your headset via DECT - a technology characterized by its reliable, long range capabilities - offering a wireless range of up to 150m. A SmartSetup wizard on the touch screen helps you connect your phones and choose preferences to get started. Once you're up and running, the screen's colorful icons and intuitive menu system make call-handling a breeze.
  • Up to 150m wireless hands-free telephony with DECT and DECT 6.0 with CA T-iq technology
    Long range and reliable connectivity gives users the freedom to multi-task with maximum efficiency and answer phone calls from any location in the office.
  • Multiuse connectivity - desk and softphone
    Allows users to switch seamlessly between calls on desk and softphones.
  • Talk time up to 8h in wideband sound mode and up to 10h in narrowband sound mode
    No need to charge headset for a full working day.
  • 2.4" Touch-sensitive screen in Q-VGA resolution for call handling, system configuration and setup wizard
    Intuitive touch screen call management. Shows active phone device and lets you redial. Easy system configuration with SmartSetup wizard.
  • Standby time 46h
    Less need to charge headset.
  • Wideband sound and DSP (Digital Signal Processing)
    Hear and be heard with digitally enhanced speech and sound in wideband quality. Helping users hear what customers are saying, this feature enhances understanding and call efficiency.
  • Supports both wideband (150-6,800 Hz) and narrowband (300-3,400 Hz) to match phone system
    Close integration with the specific type of phone system means better call clarity for both parties. Bandwidth can be selected per phone.
  • Single noise-canceling microphone with DSP
    Reduces distractions by almost eliminating background noise, so only the user's voice is transmitted.
  • Jabra SafeTone technologies
    Protects users' hearing by cutting off sound spikes and sudden loud noises (PeakStop protection) and securing safe average sound levels throughout the day (IntelliTone). Fully compliant with noise-at-work legislation.
Jabra PRO 9460 Replacement - headset
Headset - DECT - wireless
Recommended Use
Portable electronics, phone, computer - communication
Additional Functions
DSP
Headphones Form Factor
On-ear
Wireless
Wireless Technology
DECT
Sound Output Mode
Mono
Sound Effects
Crystal Clear
Audio Specifications
Frequency Response 150 - 6800 Hz - Sensitivity 93 dB
Impedance
32 Ohm
Active Noise Canceling
Microphone
Boom
Microphone Active Noise Cancelling
Controls
Mute, volume, answer/end
PRO 9460, 9460 Duo, 9460 Mono, 9460 NCSA
Headset - DECT
DSP
4.8 cm
16.3 cm
1.8 cm
31 g
Recommended Use
Max Operating Distance
150 m
Headphones
Supraaural
Wireless
Wireless Technology
DECT
Sound Output Mode
Mono
Sound Effects
Crystal Clear
Active Noise Cancelling Technology
Noise Blackout
Frequency Response
150 - 6800 Hz
Sensitivity
93 dB
Impedance
32 Ohm
Diaphragm
28 mm
SafeTone technology, PeakStop technology
Microphone
Boom
Headset microphone
Sensitivity
-34 dB
Frequency Response
150 - 6800 Hz
Audio Input Details
Uni-directional - 150 - 6800 Hz
Remote Control
Controls
Plug and Play, UL, NOM, CB, IC, PSB, FCC, TELEC, EAC, ICASA, NTC, ACMA, SIRIM
Headset battery rechargeable
Run Time (Up To)
10 hour(s)
Standby Time
38 hours
Recharge Time
2 hour(s)
Jabra PRO 9460, 9460 Duo, 9460 Mono, 9460 NCSA
Recommended Use: Phone
Recommended Use: Portable electronics
Earcover : Monaural
Brand: Jabra
Price Range Ex VAT: 50 - 100
