With Jabra PRO 9460 headset, office staff can answer calls made to either of their phones, even while away from their desks. Specially designed for open plan working environments, the model is fitted with a flex boom for optimum voice pick-up. Jabra PRO 9460 is a single-ear headset that can be worn hooked over the ear, or on a head or neckband.
The device is united by a stylish touch screen base. The base connects to your headset via DECT - a technology characterized by its reliable, long range capabilities - offering a wireless range of up to 150m. A SmartSetup wizard on the touch screen helps you connect your phones and choose preferences to get started. Once you're up and running, the screen's colorful icons and intuitive menu system make call-handling a breeze.
Up to 150m wireless hands-free telephony with DECT and DECT 6.0 with CA T-iq technology
Long range and reliable connectivity gives users the freedom to multi-task with maximum efficiency and answer phone calls from any location in the office. -
Multiuse connectivity - desk and softphone
Allows users to switch seamlessly between calls on desk and softphones. -
Talk time up to 8h in wideband sound mode and up to 10h in narrowband sound mode
No need to charge headset for a full working day. -
2.4" Touch-sensitive screen in Q-VGA resolution for call handling, system configuration and setup wizard
Intuitive touch screen call management. Shows active phone device and lets you redial. Easy system configuration with SmartSetup wizard. -
Standby time 46h
Less need to charge headset. -
Wideband sound and DSP (Digital Signal Processing)
Hear and be heard with digitally enhanced speech and sound in wideband quality. Helping users hear what customers are saying, this feature enhances understanding and call efficiency. -
Supports both wideband (150-6,800 Hz) and narrowband (300-3,400 Hz) to match phone system
Close integration with the specific type of phone system means better call clarity for both parties. Bandwidth can be selected per phone. -
Single noise-canceling microphone with DSP
Reduces distractions by almost eliminating background noise, so only the user's voice is transmitted. -
Jabra SafeTone technologies
Protects users' hearing by cutting off sound spikes and sudden loud noises (PeakStop protection) and securing safe average sound levels throughout the day (IntelliTone). Fully compliant with noise-at-work legislation.
- Jabra PRO 9460 Replacement - headset - replacement
- Product Type
- Headset - replacement - DECT - wireless
- Recommended Use
- Portable electronics, phone, computer - communication
- Additional Functions
- DSP
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wireless
- Wireless Technology
- DECT
- Sound Output Mode
- Mono
- Sound Effects
- Crystal Clear
- Audio Specifications
- Frequency Response 150 - 6800 Hz - Sensitivity 93 dB
- Impedance
- 32 Ohm
- Active Noise Canceling
- Microphone
- Boom
- Microphone Noise Cancelling
- Controls
- Mute, volume, answer/end
- Designed For
- PRO 9460, 9460 Duo, 9460 Mono, 9460 NCSA
- Product Type
- Headset - DECT - wireless
- Replacement
- DSP
- 4.8 cm
- 16.3 cm
- 1.8 cm
- 31 g
- Recommended Use
- Max Operating Distance
- 150 m
Audio Output
- On-ear
- Wireless
- DECT
- Sound Output Mode
- Mono
- Sound Effects
- Crystal Clear
- Active Noise Cancelling Technology
- Noise Blackout
- 150 - 6800 Hz
- Sensitivity
- 93 dB
- Impedance
- 32 Ohm
- Diaphragm
- 28 mm
- SafeTone technology, PeakStop technology
Microphone
- Boom
- Form Factor
- Headset microphone
- Sensitivity
- -34 dB
- 150 - 6800 Hz
- Noise Cancelling
- Audio Input Details
- Uni-directional - 150 - 6800 Hz
Remote Control
- Controls
- Plug and Play, UL, NOM, CB, IC, PSB, FCC, TELEC, EAC, ICASA, NTC, ACMA, SIRIM
- Battery
- Headset battery rechargeable
- Run Time (Up To)
- 10 hour(s)
- Standby Time
- 38 hours
- Recharge Time
- 2 hour(s)
- Designed For
- Jabra PRO 9460, 9460 Duo, 9460 Mono, 9460 NCSA
