Jabra PRO 9460 Mono Dual Connectivity NC Wireless Headset
Quicklinx: 6JJWWS00 Mfr#: 9460-25-707-102
Recommended Use: Portable electronics, Phone, Phone, Computer
Connectivity: Wireless
Earcover : Monaural
£200.90 ex VAT
£241.08 inc VAT
With Jabra PRO 9460 headset, office staff can answer calls made to either of their phones, even while away from their desks. Specially designed for open plan working environments, the model is fitted with a flex boom for optimum voice pick-up. Jabra PRO 9460 is a single-ear headset that can be worn hooked over the ear, or on a head or neckband.The device is united by a stylish touch screen base. The base connects to your headset via DECT - a technology characterized by its reliable, long range capabilities - offering a wireless range of up to 150m. A SmartSetup wizard on the touch screen helps you connect your phones and choose preferences to get started. Once you're up and running, the screen's colorful icons and intuitive menu system make call-handling a breeze.
  • One headset for all phones
    Take every call on the same headset. Connects to your desk phone, mobile and softphone ? all at the same time. Manage multiple calls through an industry-first, user-friendly touch-screen or touchpad. Also comes with a SmartSetup wizard that guides you through the connection process.
  • Outstanding sound quality
    If you talk and listen for a living, clear conversations can make or break a deal. Get best-in-class noise-cancellation and acoustic protection. Your calls will sound great ? even in the noisiest of offices. Noise Blackout ?: Ear cushions and microphone are specially designed to eliminate background noise. Digital Signal Processing and HD Voice make your calls more intelligible and lifelike. SafeTone? technology automatically counters unexpected spikes in volume and protects your ears.
  • True wireless freedom
    Wireless DECT technology allows you to roam up to 150 metres away from your desk without dropping the call. Answer and end calls remotely while multitasking around the office. With up to 10 hours of battery life, you won?t need to worry about running out of charge.
  • DECT security compliant
    Compliant with the latest security requirements of the DECT standard, designed to safeguard against eavesdropping. The Jabra-patented headset-to-base pairing process avoids risky pairing over the air to protect your conversations.
  • 10-Hour Battery Life
    Multi-device connectivity technology lets you manage phone calls from several different devices such as deskphones, tablets, PCs and smartphones, with one single headset. You get greater flexibility and enhanced user experience.
Jabra PRO 9460 - headset
Headset - wireless - DECT
Recommended Use
PC multimedia, corded phone, mobile phone
Hong Kong, Singapore, United Kingdom
Headphones Type
Headphone - monaural
Headphones Form Factor
Convertible
Wireless - DECT
Sound Output Mode
Mono
Frequency Response
150 - 6800 Hz
Microphone
Boom
2 years warranty
Headset - DECT
31 g
Recommended Use
Noise cancelling circuit, mute button, answer/end button, volume control, touch sensor operation, built-in DSP, PeakStop Technology, Jabra SafeTone technology
Headphones
Headphones Type
Convertible
Wireless - DECT
Sound Output Mode
Mono
Frequency Response
150 - 6800 Hz
Microphone
Boom
Wireless Link
Transmission Range
150 m
1 x USB cable - external , 1 x phone cable - external
Neck strap, headband, power adapter, base station, headset charging cradle, earhook
EN 60950, UL 60950, IEC 60950-1
Headset battery - rechargeable
Included Qty
1
Run Time (Up To)
10 hour(s)
Standby Time
46 hours
2 years warranty
Service & Support Details
6JJW Jabra EHS Cable For Polycom IP Phones In Stock £25.29
6JJW Jabra Electronic Hook Switch headset Adaptor In Stock £31.71
6JJW Jabra LINK Electronic Hook Switch Adapter Cable In Stock £31.71
6JJW Jabra Electronic Hook Switch Cable In Stock £24.81
6JJW Jabra Micro USB Cable 1.5M In Stock £15.68
6JJW Jabra LINK EHS-Adapter For Cisco 6945 78xx/79xx/88xx Desk Phones In Stock £24.95
Resources
The following resources are available for the Jabra PRO 9460 Mono Dual Connectivity NC Wireless Headset
Recommended Use: Phone
Recommended Use: Computer
Earcover : Monaural
Brand: Jabra
