Your basket is empty
Jabra PRO 9460 Duo Spare Headset Top Only
Quicklinx: 7C5FWS00 Mfr#: 14401-03
Recommended Use: Wireless headset system
Connectivity: Wireless
Earcover : Binaural
£109.05 ex VAT
£130.86 inc VAT
With Jabra PRO 9460 DUO headset, office staff can answer calls made to either of their phones, even while away from their desks. Specially designed for open plan working environments, Jabra PRO 9460 DUO is fitted with a flex boom for optimum voice pick-up. Providing sound for both ears, the Jabra PRO 9460 DUO blocks out background noise, making it possible to handle calls calmly and professionally at all times.
Includes only the headset top and NOT base station or charger
  • User-friendly touch screen base
    The two devices - desk and softphone - are united by a stylish touch screen base. The base connects to your headset via DECT - a technology characterized by its reliable, long range capabilities - offering a wireless range of up to 150m. A SmartSetup wizard on the touch screen helps you connect your phones and choose preferences to get started. Once you're up and running, the screen's colorful icons and intuitive menu system make call-handling a breeze.
  • Unbeatable sound
    The combination of a flex boom and noise-canceling microphone with advanced digital signal processing means your voice can always be heard clearly. Wideband quality ensures that the sound you hear is crystal clear, while SafeTone technology protects your hearing.
Jabra - headset
Headset - wireless - DECT
Recommended Use
Headphones Form Factor
On-ear
Wireless - DECT
Microphone
Boom
PRO 9460 DUO, 9465 DUO
Headset - DECT
Recommended Use
Headphones
Supraaural
Wireless - DECT
Available Microphone
Microphone
Boom
Wireless Link
Transmission Range
150 m
Run Time (Up To)
10 hour(s)
Jabra PRO 9460 DUO, 9465 DUO
Earcover : Binaural
Brand: Jabra
Price Range Ex VAT: 100 - 150
