With Jabra PRO 9460 DUO headset, office staff can answer calls made to either of their phones, even while away from their desks. Specially designed for open plan working environments, Jabra PRO 9460 DUO is fitted with a flex boom for optimum voice pick-up. Providing sound for both ears, the Jabra PRO 9460 DUO blocks out background noise, making it possible to handle calls calmly and professionally at all times.
Includes only the headset top and NOT base station or charger
User-friendly touch screen base
The two devices - desk and softphone - are united by a stylish touch screen base. The base connects to your headset via DECT - a technology characterized by its reliable, long range capabilities - offering a wireless range of up to 150m. A SmartSetup wizard on the touch screen helps you connect your phones and choose preferences to get started. Once you're up and running, the screen's colorful icons and intuitive menu system make call-handling a breeze. -
Unbeatable sound
The combination of a flex boom and noise-canceling microphone with advanced digital signal processing means your voice can always be heard clearly. Wideband quality ensures that the sound you hear is crystal clear, while SafeTone technology protects your hearing.
- Jabra PRO 9400 Replacement - headset
- Product Type
- Headset - DECT 6.0 - wireless
- Recommended Use
- Portable electronics, phone, computer - communication
- Additional Functions
- DSP
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wireless
- Wireless Technology
- DECT 6.0
- Sound Output Mode
- Stereo
- Sound Effects
- Crystal Clear
- Audio Specifications
- Frequency Response 150 - 6800 Hz - Sensitivity 97 dB
- Impedance
- 32 Ohm
- Active Noise Canceling
- Microphone
- Boom
- Microphone Active Noise Cancelling
- Controls
- Mute, volume, answer/end
- Designed For
- PRO 9460 Duo, 9465 Duo
- Product Type
- DSP
- 16.5 cm
- 16.5 cm
- 3.5 cm
- 70 g
- Recommended Use
- Max Operating Distance
- 150 m
Headphones
- On-ear
- Wireless
- DECT 6.0
- Sound Output Mode
- Stereo
- Sound Effects
- Crystal Clear
- Active Noise Cancelling Technology
- Noise Blackout
- 150 - 6800 Hz
- Sensitivity
- 97 dB
- Impedance
- 32 Ohm
- Diaphragm
- 23 mm
- SafeTone technology, PeakStop technology
Microphone
- Boom
- Form Factor
- Headset microphone
- Sensitivity
- -34 dB
- 150 - 6800 Hz
- Audio Input Details
- Uni-directional - 150 - 6800 Hz
Remote Control
- Controls
- Plug and Play, UL, NOM, CB, IC, PSB, FCC, TELEC, EAC, ICASA, NTC, ACMA, SIRIM
- Battery
- Headset battery rechargeable
- Run Time (Up To)
- 10 hour(s)
- Standby Time
- 38 hours
- Recharge Time
- 2 hour(s)
- Designed For
- Jabra PRO 9460 Duo, 9465 Duo
