Jabra PRO 9460 Duo Spare Headset (Top Only)
Quicklinx: 7C5FWS00 Mfr#: 14401-03
Recommended Use: Portable electronics, Computer, Phone, Phone
Connectivity: Wireless
Earcover : Binaural
£115.95 ex VAT
£139.14 inc VAT
With Jabra PRO 9460 DUO headset, office staff can answer calls made to either of their phones, even while away from their desks. Specially designed for open plan working environments, Jabra PRO 9460 DUO is fitted with a flex boom for optimum voice pick-up. Providing sound for both ears, the Jabra PRO 9460 DUO blocks out background noise, making it possible to handle calls calmly and professionally at all times.
Includes only the headset top and NOT base station or charger
  • User-friendly touch screen base
    The two devices - desk and softphone - are united by a stylish touch screen base. The base connects to your headset via DECT - a technology characterized by its reliable, long range capabilities - offering a wireless range of up to 150m. A SmartSetup wizard on the touch screen helps you connect your phones and choose preferences to get started. Once you're up and running, the screen's colorful icons and intuitive menu system make call-handling a breeze.
  • Unbeatable sound
    The combination of a flex boom and noise-canceling microphone with advanced digital signal processing means your voice can always be heard clearly. Wideband quality ensures that the sound you hear is crystal clear, while SafeTone technology protects your hearing.
Jabra PRO 9400 Replacement - headset
Headset - replacement - DECT 6.0 - wireless
Recommended Use
Portable electronics, phone, computer - communication
Additional Functions
DSP
Headphones Form Factor
On-ear
Wireless
Wireless Technology
DECT 6.0
Sound Output Mode
Stereo
Sound Effects
Crystal Clear
Audio Specifications
Frequency Response 150 - 6800 Hz - Sensitivity 97 dB
Impedance
32 Ohm
Active Noise Canceling
Microphone
Boom
Microphone Active Noise Cancelling
Controls
Mute, volume, answer/end
PRO 9460 Duo, 9465 Duo
Headset - DECT 6.0 - wireless
Replacement
DSP
16.5 cm
16.5 cm
3.5 cm
70 g
Recommended Use
Max Operating Distance
150 m
Audio Output
On-ear
Wireless
Wireless Technology
DECT 6.0
Sound Output Mode
Stereo
Sound Effects
Crystal Clear
Active Noise Cancelling Technology
Noise Blackout
Frequency Response
150 - 6800 Hz
Sensitivity
97 dB
Impedance
32 Ohm
Diaphragm
23 mm
SafeTone technology, PeakStop technology
Microphone
Boom
Headset microphone
Sensitivity
-34 dB
Frequency Response
150 - 6800 Hz
Noise Canceling
Audio Input Details
Uni-directional - 150 - 6800 Hz
Remote Control
Controls
Plug and Play, UL, NOM, CB, IC, PSB, FCC, TELEC, EAC, ICASA, NTC, ACMA, SIRIM
Headset battery rechargeable
Run Time (Up To)
10 hour(s)
Standby Time
38 hours
Recharge Time
2 hour(s)
Jabra PRO 9460 Duo, 9465 Duo
Recommended Use: Computer
Recommended Use: Phone
Earcover : Binaural
Brand: Jabra
