Jabra PRO 9450 Mono Midi Boom Spare Headset
Quicklinx: 8HHMWS00 Mfr#: 14401-07
The Jabra PRO 9450 dual connectivity headset is a user-friendly, no-frills device which provides office staff with a straightforward interface to handle calls from both desk phones and UC softphones. It is therefore ideal for companies in transition to UC, or indeed any organization using a combination of these two types of phones. With Jabra PRO 9450, everyone has an opportunity to benefit from true wireless working and enhanced productivity!
Jabra PRO 9450 Replacement - headset - replacement
Headset - replacement - DECT - wireless
Recommended Use
Portable electronics, phone, computer - communication
Additional Functions
DSP
Headphones Form Factor
On-ear
Wireless
Wireless Technology
DECT
Sound Output Mode
Mono
Sound Effects
Crystal Clear
Audio Specifications
Frequency Response 150 - 6800 Hz - Sensitivity 93 dB
Impedance
32 Ohm
Active Noise Canceling
Microphone
Boom
Microphone Noise Cancelling
Controls
Mute, volume, answer/end
PRO 9450, 9450 Duo, 9450 Duo NCSA, 9450 Flex
Headset - DECT - wireless
Replacement
DSP
4.8 cm
13 cm
1.8 cm
28 g
Recommended Use
Max Operating Distance
150 m
Audio Output
On-ear
Wireless
Wireless Technology
DECT
Sound Output Mode
Mono
Sound Effects
Crystal Clear
Active Noise Cancelling Technology
Noise Blackout
Frequency Response
150 - 6800 Hz
Sensitivity
93 dB
Impedance
32 Ohm
Diaphragm
28 mm
SafeTone technology, PeakStop technology
Microphone
Boom
Headset microphone
Sensitivity
-30 dB
Frequency Response
150 - 6800 Hz
Noise Cancelling
Audio Input Details
Uni-directional - 150 - 6800 Hz
Remote Control
Controls
Plug and Play, UL, NOM, CB, IC, PSB, FCC, TELEC, EAC, ICASA, NTC, ACMA, SIRIM
Headset battery rechargeable
Run Time (Up To)
10 hour(s)
Standby Time
38 hours
Recharge Time
2 hour(s)
Jabra PRO 9450, 9450 Duo, 9450 Duo NCSA, 9450 Flex
