Jabra PRO 9450 Duo Flex Boom Wireless Headset
Quicklinx: 81QSWS00 Mfr#: 9450-29-707-102
The Jabra Pro 9450 duo wireless headset delivers up to 150 metres of range and connects to your mobile, deskphone or softphone. This versatile headset also features a noise-cancelling microphone, acoustic protection and wideband audio quality.
  • One headset for all phones
    Take every call on the same headset. Connects to your desk phone, mobile and softphone - all at the same time. Manage multiple calls through an industry-first, user-friendly touch-screen or touchpad. Also comes with a SmartSetup wizard that guides you through the connection process.
  • Outstanding sound quality
    If you talk and listen for a living, clear conversations can make or break a deal. Get best-in-class noise-cancellation and acoustic protection. Your calls will sound great – even in the noisiest of offices. Noise Blackout : Ear cushions and microphone are specially designed to eliminate background noise. Digital Signal Processing and HD Voice make your calls more intelligible and lifelike. SafeTone technology automatically counters unexpected spikes in volume and protects your ears.
  • True wireless freedom
    Wireless DECT technology allows you to roam up to 150 metres away from your desk without dropping the call. Answer and end calls remotely while multitasking around the office. With up to 10 hours of battery life, you won't need to worry about running out of charge.
  • DECT security compliant
    Compliant with the latest security requirements of the DECT standard, designed to safeguard against eavesdropping. The Jabra-patented headset-to-base pairing process avoids risky pairing over the air to protect your conversations.
  • 10-Hour Battery Life
    Multi-device connectivity technology lets you manage phone calls from several different devices such as deskphones, tablets, PCs and smartphones, with one single headset. You get greater flexibility and enhanced user experience.
Jabra PRO 9450 Duo - headset
Headset - DECT - wireless
Recommended Use
Phone, computer
Headphones Form Factor
Convertible
Wireless
Wireless Technology
DECT
Sound Output Mode
Mono
Audio Specifications
Frequency Response 150 - 6800 Hz
Active Noise Canceling
Microphone
Boom
Controls
Mute, volume, answer/end
28 g
Recommended Use
Phone, computer
Max Operating Distance
150 m
Audio Output
Convertible
Wireless
Wireless Technology
DECT
Sound Output Mode
Mono
Active Noise Cancelling Technology
Noise Blackout
Frequency Response
150 - 6800 Hz
Microphone
Boom
Remote Control
Controls
Wireless Link
Transmission Range
150 m
Headband, power adapter, USB cable, telephone cable, base station, headset charging cradle, earhook
Cable Details
USB cable , Phone cable
Headset battery rechargeable
Included Qty
1
315 mAh
Run Time (Up To)
10 hour(s)
Standby Time
46 hours
81QS Jabra DHSG Cable In Stock £20.79
81QS Jabra LINK EHS-Adapter For Cisco 6945 78xx/79xx/88xx Desk Phones In Stock £26.40
