Jabra PRO 935 Mono Wireless Headset
Quicklinx: 9BMQWS00 Mfr#: 935-15-509-202
Recommended Use: Phone, Phone, Portable electronics
Connectivity: Wireless
Earcover : Monaural
£148.41 ex VAT
£178.09 inc VAT
The Jabra Pro 920 headset is a professional wireless headset designed for maximum performance. Now everyone in your office can take advantage of the added productivity and comfort that wireless convenience delivers. Simple, intuitive and high quality, all-in-one wireless solution.
With the DECT wireless technology you get up to 120 metres hands-free communication for your deskphone. Talk for up to 8 hours with no battery life concerns.
Wireless headset range
Bring your conversation to the coffee machine, colleague or private room. The Jabra PRO 900 DECT variants give you the wireless freedom to walk and talk at up to 120 metres of range (or 100 metres for Bluetooth variants).
World-class sound
Lifelike conversations require great, ambient-noise reducing speakers and a noise-cancelling microphone that also avoids air shocks. With Jabra PRO 900, you can get both - and choose between a range of mono and duo variants.
Easy to use with all-day battery
The Jabra PRO 900 is easy to set up and get started. Each headset comes with a pre-connected charging base so you can make calls straight away. With up to 12 hours of battery time, you'll never have to worry about running out.
  • Wireless headset range
  • World-class sound
    Lifelike conversations require great, ambient-noise reducing speakers and a noise-cancelling microphone that also avoids air shocks. With Jabra PRO 900, you can get both – and choose between a range of mono and duo variants.
  • Easy to use with all-day battery
  • 12-Hour Battery Life
    Multi-device connectivity technology lets you manage phone calls from several different devices such as deskphones, tablets, PCs and smartphones, with one single headset. You get greater flexibility and enhanced user experience.
  • Dual Connectivity
  • Hot Desking
    Save time, money and office space and give mobile employees a more flexible work environment. A Jabra headset with hot-desking capabilities enables multiple employees to use the same office space at different times. Just plug in your headset to any compatible base and you’re ready to work.
  • Tap-To-Connect
    Near Field Communication technology (NFC) makes it easy for your Jabra device to instantly connect and interact with phones, tablets, and interactive tags. It requires no more than a simple touch. Just tap the phone and the Jabra device together and you are ready to talk or stream your music.
  • UC Plug-And-Play
    Jabra's intelligent Call Assist lets you take a call without a click. Built-in motion sensor technology turns the headset on when you pick it up or touch it, and automatically answers the call when you place it on your ear. If you are already wearing the headset, you can accept or reject a call using just your voice.
Jabra PRO 935 Dual Connectivity - headset
Headset - Bluetooth - wireless - NFC
Headphones Form Factor
On-ear - convertible
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.0
Sound Output Mode
Mono
Microphone
Boom
Controls
Mute
Headset - Bluetooth - NFC
5 cm
1.8 cm
13.1 cm
28 g
Max Operating Distance
100 m
Headphones
Supraaural - convertible
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.0
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP)
Sound Output Mode
Mono
Microphone
Boom
Remote Control
Controls
Mute
Wireless Link
Transmission Range
100 m
Headband, power adapter, base station
Headset battery rechargeable
Run Time (Up To)
12 hour(s)
Standby Time
168 hours
9BMQ Jabra GN9300, PRO and GO Unit Power Supply Unit In Stock £15.91
9BMQ Jabra PRO 900 and 9400 Series Earhook In Stock £6.29
9BMQ Jabra Mini USB Cord For PRO 900 In Stock £15.91
Recommended Use: Portable electronics
Earcover : Monaural
Brand: Jabra
Price Range Ex VAT: 100 - 150
