Jabra Pro 930 Mono UC Wireless USB Headset
Quicklinx: 7VKNWS00 Mfr#: 930-25-509-102
Recommended Use: Computer, Desktop PC
Connectivity: Wireless
Earcover : Monaural
More than 50 in stock
£129.74 ex VAT
£155.68 inc VAT
The Jabra Pro 920 headset is a professional wireless headset designed for maximum performance. Now everyone in your office can take advantage of the added productivity and comfort that wireless convenience delivers. Simple, intuitive and high quality, all-in-one wireless solution.
With the DECT wireless technology you get up to 120 metres hands-free communication for your deskphone. Talk for up to 8 hours with no battery life concerns.
Wireless headset range
Bring your conversation to the coffee machine, colleague or private room. The Jabra PRO 900 DECT variants give you the wireless freedom to walk and talk at up to 120 metres of range (or 100 metres for Bluetooth variants).
World-class sound
Lifelike conversations require great, ambient-noise reducing speakers and a noise-cancelling microphone that also avoids air shocks. With Jabra PRO 900, you can get both - and choose between a range of mono and duo variants.
Easy to use with all-day battery
The Jabra PRO 900 is easy to set up and get started. Each headset comes with a pre-connected charging base so you can make calls straight away. With up to 12 hours of battery time, you'll never have to worry about running out.
  • Wireless headset range
  • World-class sound
    Lifelike conversations require great, ambient-noise reducing speakers and a noise-cancelling microphone that also avoids air shocks. With Jabra PRO 900, you can get both – and choose between a range of mono and duo variants.
  • Easy to use with all-day battery
  • 8-Hour Battery Life
    Multi-device connectivity technology lets you manage phone calls from several different devices such as deskphones, tablets, PCs and smartphones, with one single headset. You get greater flexibility and enhanced user experience.
  • UC Plug-And-Play
    Jabra's intelligent Call Assist lets you take a call without a click. Built-in motion sensor technology turns the headset on when you pick it up or touch it, and automatically answers the call when you place it on your ear. If you are already wearing the headset, you can accept or reject a call using just your voice.
Jabra PRO 930 - headset
Headset - DECT - wireless
Headphones Form Factor
Convertible
Wireless
Wireless Technology
DECT
Sound Output Mode
Mono
Microphone
Boom
Controls
Mute, volume, answer/end
Headset - DECT
27 g
Max Operating Distance
120 m
Headphones
Convertible
Wireless
Wireless Technology
DECT
Sound Output Mode
Mono
Microphone
Boom
Remote Control
Controls
Wireless Link
Transmission Range
120 m
USB cable
Plug and Play, EN 60950, UL 60950, IEC 60950-1
Headset battery rechargeable
Included Qty
1
Run Time (Up To)
8 hour(s)
Standby Time
36 hours
7VKN Jabra GN9300, PRO and GO Unit Power Supply Unit In Stock £15.91
7VKN Jabra PRO 900 and 9400 Series Earhook In Stock £6.29
7VKN Jabra Pro 900 Series Mono Headset (Top Only) In Stock £84.08
7VKN Jabra Mini USB Cord For PRO 900 In Stock £15.91
Resources
The following resources are available for the Jabra Pro 930 Mono UC Wireless USB Headset
Recommended Use: Desktop PC
Earcover : Monaural
Brand: Jabra
Price Range Ex VAT: 100 - 150
