Jabra PRO 930 Duo USB Wireless Headset
Quicklinx: BL6NWS00 Mfr#: 930-29-509-102
Recommended Use: Phone, Phone
Connectivity: Wireless
Earcover : Binaural
£131.83 ex VAT
£158.19 inc VAT
It's a professional wireless headset that comes with your choice of connectivity possibilities and a pre-connected base. A simple, reliable and affordable way to go wireless - wherever you work.
  • Wireless headset range
    Bring your conversation to the coffee machine, colleague or private room. The Jabra PRO 900 DECT variants give you the wireless freedom to walk and talk at up to 120 metres of range (or 100 metres for Bluetooth variants).
  • World-class sound
    Lifelike conversations require great, ambient-noise reducing speakers and a noise-cancelling microphone that also avoids air shocks. With Jabra PRO 900, you can get both – and choose between a range of mono and duo variants.
  • Easy to use with all-day battery
    The Jabra PRO 900 is easy to set up and get started. Each headset comes with a pre-connected charging base so you can make calls straight away. With up to 12 hours of battery time, you'll never have to worry about running out.
Jabra PRO 930 Duo - headset
Headset - DECT CAT-iq - wireless
Recommended Use
Phone
Additional Functions
LED lights
Headphones Form Factor
On-ear
Wireless
Wireless Technology
DECT CAT-iq
Radio Frequency Range
1.88 - 1.9GHz, 1.92 - 1.93GHz
Microphone
Boom
Controls
Mute, volume control, answer/end
LED lights
7.6 cm
2.9 cm
11.8 cm
Recommended Use
Phone
Max Operating Distance
120 m
Headphones
On-ear
Wireless
Wireless Technology
DECT CAT-iq
Microphone
Boom
Remote Control
Controls
Wireless Link
Transmission Range
120 m
Connector Type
USB
USB charge cable
Base stand
Headset battery rechargeable - lithium polymer
295 mAh
Run Time (Up To)
8 hour(s)
Standby Time
36 hours
Recharge Time
3 hour(s)
Earcover : Binaural
Brand: Jabra
Price Range Ex VAT: 100 - 150
