Jabra PRO 920 Duo Wireless Headset
Quicklinx: BL6KWS00 Mfr#: 920-29-508-102
Recommended Use: Phone, Phone
Connectivity: Wireless
Select:
Hurry, only 2 left in stock!
£125.00 ex VAT
£150.00 inc VAT
Express delivery Order within the next 22 hours for delivery on Thursday
The Jabra PRO 900 DECT variants gives you the wireless freedom to walk and talk at up to 120 meters of range or 100 meters for Bluetooth variants.
Never miss a word of what's being said. Enjoy crystal clear conversations with high definition sound. Protective features like SafeTone cut off loud noises and protects your hearing.
Jabra PRO 900 is easy to set up and get started with. Each headset comes with a pre connected base so you can make calls straight away.
  • Wireless headset range
    Bring your conversation to the coffee machine, colleague or private room. The Jabra PRO 900 DECT variants give you the wireless freedom to walk and talk at up to 120 metres of range (or 100 metres for Bluetooth variants).
  • World-class sound
    Lifelike conversations require great, ambient-noise reducing speakers and a noise-cancelling microphone that also avoids air shocks. With Jabra PRO 900, you can get both – and choose between a range of mono and duo variants.
  • Easy to use with all-day battery
    The Jabra PRO 900 is easy to set up and get started. Each headset comes with a pre-connected charging base so you can make calls straight away. With up to 12 hours of battery time, you'll never have to worry about running out.
  • 8-Hour Battery Life
    Multi-device connectivity technology lets you manage phone calls from several different devices such as deskphones, tablets, PCs and smartphones, with one single headset. You get greater flexibility and enhanced user experience.
Jabra PRO 920 Duo - headset
Headset - DECT - wireless
Recommended Use
Phone
Hong Kong, Singapore, United Kingdom
Headphones Form Factor
On-ear - convertible
Wireless
Wireless Technology
DECT
Sound Output Mode
Stereo
Microphone
Boom
Controls
Mute
27 g
Recommended Use
Phone
Max Operating Distance
120 m
Audio Output
Wireless
Wireless Technology
DECT
Sound Output Mode
Stereo
Microphone
Boom
Remote Control
Controls
Mute
Wireless Link
Transmission Range
120 m
Power adapter, base station
Headset battery rechargeable
Included Qty
1
Run Time (Up To)
8 hour(s)
Standby Time
36 hours
Brand: Jabra
Stock Status: While stocks last
Stock Status: Clearance
