Jabra Play - White
Jabra Play - White
Quicklinx: 8ZX8WS00 Mfr#: 100-96900001-60
No pockets? No problem. The wonderful Jabra PLAY is a high performance and stylish Bluetooth stereo headset that acts as a remote control to your mobile phone. So you can play music and take calls anywhere while leaving your phone in your pocket. Just swing it around your neck and you’re on.
Jabra PLAY gives you easy control of music and calls, all with high performance digital sound quality, wireless streaming and earphones designed to isolate the noise from outside. When a call comes in the headset alerts you. With one tap you can take a call and once the call ends you can go back to enjoying your music with easy controls for volume and skipping tracks.
  • Wireless music and calls on the go
  • Switch between music and calls - seamlessly
  • Take it anywhere
    Thanks to the stereo headset's unique design, Jabra PLAY gives you all the flexibility you need. You can wear it the way you want - hang it or clip it on, you choose. Either way it’s guaranteed to turn heads.
  • All the music you want
    With a minimum of 6 hours music time and 6 hours of talk time, you’re free to go as far as you like, without ever having to take your phone out of your pocket.
Jabra Play - earphones with mic
Earphones - Bluetooth - wireless
Recommended Use
Portable electronics
White
Headphones Form Factor
In-ear binaural
Wireless
Wireless Technology
Bluetooth
Sound Output Mode
Stereo
Microphone
Built-in
Controls
Volume, answer/end, play/pause
10.6 g
White
Recommended Use
Audio Output
In-ear binaural
Wireless
Wireless Technology
Bluetooth
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP)
Sound Output Mode
Stereo
Remote Control
Controls
Connector Type
USB
Power adapter - external
Headphone battery rechargeable
Run Time (Up To)
6 hour(s)
Standby Time
192 hours
