No pockets? No problem. The wonderful Jabra PLAY is a high performance and stylish Bluetooth stereo headset that acts as a remote control to your mobile phone. So you can play music and take calls anywhere while leaving your phone in your pocket. Just swing it around your neck and you’re on.
Jabra PLAY gives you easy control of music and calls, all with high performance digital sound quality, wireless streaming and earphones designed to isolate the noise from outside. When a call comes in the headset alerts you. With one tap you can take a call and once the call ends you can go back to enjoying your music with easy controls for volume and skipping tracks.
Wireless music and calls on the go
No pockets? No problem. The wonderful Jabra PLAY is a high performance and stylish Bluetooth stereo headset that acts as a remote control to your mobile phone. So you can play music and take calls anywhere while leaving your phone in your pocket. Just swing it around your neck and you’re on. -
Switch between music and calls - seamlessly
Jabra PLAY gives you easy control of music and calls, all with high performance digital sound quality, wireless streaming and earphones designed to isolate the noise from outside. When a call comes in the headset alerts you. With one tap you can take a call and once the call ends you can go back to enjoying your music with easy controls for volume and skipping tracks. -
Take it anywhere
Thanks to the stereo headset's unique design, Jabra PLAY gives you all the flexibility you need. You can wear it the way you want - hang it or clip it on, you choose. Either way it’s guaranteed to turn heads. -
All the music you want
With a minimum of 6 hours music time and 6 hours of talk time, you’re free to go as far as you like, without ever having to take your phone out of your pocket.
- Jabra Play - earphones with mic
- Product Type
- Earphones - Bluetooth - wireless
- Recommended Use
- Portable electronics
- White
- Headphones Form Factor
- In-ear binaural
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Sound Output Mode
- Stereo
- Microphone
- Built-in
- Controls
- Volume, answer/end, play/pause
- Product Type
- 10.6 g
- White
- Recommended Use
Audio Output
- In-ear binaural
- Wireless
- Bluetooth
- Bluetooth Profiles
- Advanced Audio Distribution Profile (A2DP)
- Sound Output Mode
- Stereo
Remote Control
- Controls
- Connector Type
- USB
- Power Device
- Power adapter - external
- Battery
- Headphone battery rechargeable
- Run Time (Up To)
- 6 hour(s)
- Standby Time
- 192 hours
