Jabra Noise Guide
Jabra Noise Guide
Quicklinx: C3HCWS00 Mfr#: 14207-36
Jabra Noise Guide measurement unit provides you with 2 types of measurements simultaneously. The ear symbol indicates the state of the current noise level while the LED panel at the bottom of the device indicates the average noise level over the past 15 minutes.
  • CUSTOMISE SENSITIVITY LEVELS FOR SPECIFIC NEEDS
    You can customise the unit to be more or less sensitive to noise – depending on whether it's in a quiet office or a noisier one. As your company grows, use this to set when the unit should turn green, yellow or red.
  • MEASURE UNDERLYING NOISE TRENDS
    Measure and record daily noise levels over a period of up to three months. This can help identify and track problem areas in the office. Download noise data to a PC or a USB stick and analyse it using special SoundEar 3 software.
  • OPEN OFFICES ARE NOISY OFFICES
    Open-plan offices are becoming increasingly popular, because they improve teamwork and communication between colleagues. Unfortunately, open-plan offices also tend to be noisier than other workspaces. As many as 35% of knowledge workers say they are disturbed by colleagues talking nearby. Jabra Noise Guide is a portable device that monitors noise levels and makes people more aware of the impact noise has on their work. You can use it to identify especially noisy areas and encourage workers to reduce office noise.
  • VISUAL FEEDBACK ON NOISE LEVELS
    Get instant visual feedback when noise levels exceed a set limit. The Instant Feedback Technology will make the unit turn red, yellow or green to make people aware of the current noise level. This encourages everyone to reduce the noise, creating a better working environment.
Jabra - noise guide
Noise guide
Package Content
USB adapter cable, USB flash drive, AC power adapter (EU/UK/US plugs), noise guide
Noise guide
Package Content
