The Jabra Motion™ UC lets you focus on your conversation, not technology, with intuitive features that adapt to your environment and movement. Connect to all your phones with one headset, and transfer calls between phones as you head out the door. Roam up to 100 m/300 ft and enjoy all-day talk time with exceptional call quality and comfort.
USB adapter enables UC integration. Soft pouch included.
Superior Sound
Experience crystal clear call quality wherever you are - even in noisy, windy environments. The intuitive 'Power Nap' mode makes the headset power down when not in use to give you more talk time. -
All-day Comfort
Get maximum comfort with a behind-the-ear design and flexible materials that hug your ear. Find the perfect fit by adjusting the speaker and flipping it to fit either ear. -
Smart Motion Sensor
Answer calls by simply picking up the headset. When lying still, the motion sensor activates a "Power Nap" mode to save battery. Lift the headset, and it's ready to go again.
- Jabra Motion Office - headset
- Product Type
- Headset - Bluetooth - wireless
- Recommended Use
- Portable electronics, computer
- Headphones Form Factor
- Ear-bud - over-the-ear mount - monaural
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 4.0
- Sound Output Mode
- Mono
- Active Noise Canceling
- Microphone
- Boom
- Controls
- Mute
- Product Type
- Recommended Use
- Max Operating Distance
- 100 m
Audio Output
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 4.0
- Bluetooth Profiles
- Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP)
- Sound Output Mode
- Mono
- Active Noise Cancelling Technology
- Noise Blackout
Microphone
- Boom
Remote Control
- Controls
- Mute
Wireless Link
- Transmission Range
- 100 m
- Included Accessories
- Carrying pouch, Bluetooth USB adapter, 3 pairs of gel ear tips, touch screen base station
- Cable Details
- USB cable
- Battery
- Headset battery rechargeable
- Included Qty
- 1
- Run Time (Up To)
- 8 hour(s)
Jabra DHSG Cable | In Stock | £26.32 |
Jabra Electronic Hook Switch Cable | In Stock | £24.93 |
