Your basket is empty
Jabra Mini (no charger)
Quicklinx: BRHWWS00 Mfr#: 100-92310000-60
Jabra Mini is definitely a tiny headset, but in no way does it compromise on sound quality for the sake of being small. Jabra Mini puts hands free communication in the palm of your hand and crystal clear audio in your ear with the tried and tested HD Voice technology.
The compact design of this tiny Bluetooth headset does not put a limit to the functionality of Jabra Mini. With the three intuitive buttons you can do everything you need - turn the headset on/off, answer or reject calls, and control the volume too. Jabra Mini also comes with voice guidance to notify you of the connection status to your device and when you need to recharge your headset.
Jabra Mini - headset
Headset - Bluetooth - wireless
Recommended Use
Portable electronics
Headphones Form Factor
In-ear - convertible
Wireless
Wireless Technology
Bluetooth
Headphones Technology
Dynamic
Bluetooth Version
Bluetooth 4.0
Sound Output Mode
Mono
Microphone
Built-in
Controls
Mute, volume, on/off, answer/end
Headset - Bluetooth
1.47 cm
4.71 cm
0.99 cm
10 g
Recommended Use
Max Operating Distance
30 m
Headphones
Dynamic
Wireless
Wireless Technology
Bluetooth
Available Microphone
Bluetooth Version
Bluetooth 4.0
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP)
Sound Output Mode
Mono
Diaphragm
11 mm
Microphone
Audio Input Details
Omni-directional
Remote Control
Controls
Wireless Link
Transmission Range
30 m
Connector Type
USB (mini-USB Type A)
USB charge cable
2 earhooks, 2 gel ear tips
1 x headset battery rechargeable
Included Qty
1
Run Time (Up To)
9 hour(s)
Standby Time
216 hours
