Your basket is empty
Jabra LINK EHS Cable - Avaya 1600 and 9600 Series
Quicklinx: 84M1WS00 Mfr#: 14201-35
Recommended Use: Accessory
Connectivity: [N/A]
Earcover : [N/A]
Stock Status: Used Stock
£30.80 ex VAT
£36.96 inc VAT
Enjoy wireless freedom and get remote call control on your wireless headset from a wide range of Avaya deskphones using an Electronic Hook Switch (EHS) cord. Answer or end calls, mute the microphone and adjust volume when you are away from the desk.
Jabra LINK - electronic hook switch adapter
Electronic hook switch adapter
2 years warranty
Avaya one-X Deskphone Edition 9610, 9620, 9620C, 9620L, 9630, 9630G, 9640, 9640G, 9650, 9650C, 9670G; one-X Deskphone Value Edition 1603, 1603-I, 1603SW, 1603SW-I, 1608, 1608-I, 1616, 1616-I
Volume control
2 years
Avaya one-X Deskphone Edition 9610 IP Telephone, 9620 IP Telephone, 9620C IP Telephone, 9620L IP Telephone, 9620L IP Telephone w/o faceplate, 9630 IP Telephone, 9630G IP Telephone, 9640 IP Telephone, 9640G IP Telephone, 9640G IP Telephone w/o faceplate, 9650 IP Telephone, 9650C IP Telephone, 9670G , Avaya one-X Deskphone Value Edition 1603, 1603-I, 1603SW, 1603SW-I, 1608, 1608-I, 1616, 1616-I
Used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Accessories Packaging Functional Software Manuals
Ref: 84M1 029624
Condition: Customer return - item has been used and shows signs of use
This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £3.82
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Connectivity: [N/A]
Earcover : [N/A]
Brand: Jabra
Price Range Ex VAT: 0 - 50
