Jabra LINK 360 USB Bluetooth Adapter
Quicklinx: 982SWS00 Mfr#: 14208-01
  • Bluetooth 3.0
£37.59 ex VAT
£45.10 inc VAT
The Jabra LINK 360 is a plug-and-play Bluetooth mini USB adapter suitable for staying in PC at all times. It connects your Bluetooth headset with your PC. With a range of up to 100 meters (depending on the headset), employees can enjoy freedom of movement while talking on the phone. Capable of streaming music from PC in an outstanding quality (headsets supporting A2DP).
  • Call control at your fingertips
    Convenient call control from your Bluetooth audio device lets you enjoy quick, optimised use of your softphone. At the press of a button you can answer/end calls, put calls on hold, adjust volume and mute the microphone.
  • Crystal clear sound
    Jabra Link 360 incorporates a number of sound quality features, such as HD Voice for crystal clear conversations and HiFi Audio Streaming with A2DP, that allows you to stream music, podcasts and GPS directions in HiFi quality.
  • Superior range for optimal mobility
    The Jabra Link 360 Bluetooth adapter gives you the freedom to move about in and outside of the office. Its Bluetooth Class 1 secures a best-in-class range of up to 100m from your PC, so you can call and multitask on your terms.
Jabra LINK 360 - network adapter
Network adapter
External
Interface (Bus) Type
USB 2.0
Bluetooth 3.0
Bluetooth Class
Class 1
Bluetooth 3.0
Network adapter
External
USB 2.0
Wireless
Bluetooth 3.0
Bluetooth Class
Class 1
Bluetooth Profiles
Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP), Device ID Profile (DIP)
Max Range Open Space
100 m
Bluetooth 3.0
1 x USB 2.0 - 4 pin USB Type A
Brand: Jabra
Price Range Ex VAT: 0 - 50
