Jabra LINK 280 USB Cable
Quicklinx: 7061WS00 Mfr#: 280-09
Recommended Use: Accessory
Connectivity: Wired
Earcover : [N/A]
£72.09 ex VAT
£86.50 inc VAT
Jabra Link 280 QD to USB adapter provides a nice migration for corded headset users to go to USB without having to purchase a separate USB headset. The Jabra Link 280 provides integrated inline controls to handle ring tone.
  • Built to stand up to the worst punishment a high volume contact centre can deliver
    To ensure long service life, Jabra Link 280 is made of durable high-quality materials designed to withstand heavy use in high volume contact centre environments.
  • Call control at your fingertips
    Convenient in-line control buttons let you enjoy quick, optimised use of your softphone. At the press of a button you can answer/end calls, put calls on hold, adjust volume and mute the microphone. Two of the four buttons can be programmed from the computer to perform user-defined tasks such as "answer mobile phone call" – or to comply with commands in future softphones.
  • Crystal clear conversation
    Jabra Link 280 incorporates a number of sound quality features, such as Digital Signal Processing (DSP) for greater intelligibility and noise filtering for a cleaner, distortion-free and smooth audio experience.
  • Prevent stress and hearing injuries
    Reduce the number of sick days and increase employee retention. Jabra Link 280 delivers acoustic shock protection and is compliant with EU Control of Noise-at-Work legislation (Directive 2003/10/EC).
  • Protect your headset investment
    Jabra Link 280 is compatible with any corded Jabra QD headset and all leading brands of softphones and mobile devices. As a result, users can continue to leverage the benefits of a professional Jabra headset, including superior sound, noise-cancelling microphone and all-day wearing comfort. This makes it the ideal solution for contact centres that want a smooth and cost-effective transition to a Unified Communications solution.
Jabra LINK 280 - adapter for headset
Adapter
Intended For
Headset
Wireless Interface
Bluetooth
48 g
Jabra GN 2000, GN 2100, GN 2100 3-in-1, GN2000; BIZ 2400, 2400 3in1
Adapter
Intended For
Headset
Wireless Interface
Bluetooth
48 g
PC Connection via USB, control buttons
Jabra GN 2000 Duo Flex. NC, GN 2000 Duo. Omni, GN 2000 Flex Mono, GN 2000 IP, GN 2000 Mono, GN 2000 Mono. Omni, GN 2000 NC Mono, GN 2000 NC Mono IP OC, GN 2000 Sound Tube Mono, GN 2000 Standard Mono Flex, GN 2100, GN 2100 3-in-1, GN 2100 DUO, GN 2100 Fixed-Boom, GN 2100 Fixed-boom 3-in-1, GN 2100 Fixed-Boom Duo, GN 2100 Flex-Boom, GN 2100 Flex-Boom 3-in-1, GN 2100 Flex-Boom Duo, GN 2100 Micro Boom LS, GN 2100 Micro-Boom, GN 2100 Micro-Boom 3-in-1, GN 2100 Micro-Boom Duo, GN 2100 Telecoil, GN 2100 USB, GN 2100 VoIP 3-i-1 Flex. NC, GN 2100 VoIP Duo Flex. NC, GN2000, GN2000 Duo, GN2000 Duo, Narrow Band, GN2000 Duo, SoundTube, GN2000 Duo, SoundTube, Narrow Band, GN2000 IP Duo NC, GN2000 IP Mono Flex. NC, GN2000 IP OC Mono, GN2000 Mono Flex. NC, GN2000 MONO NC WB, GN2000 MONO SOUNDTUBE WB, GN2000 Mono, SoundTube, Narrow Band, GN2000 Mono, USB NC, GN2000 MS Duo NC IP, GN2000 MS USB Duo, GN2000 MS USB Mono, GN2000 NC Duo, GN2000 NC DUO WB, GN2000 Sound Tube Duo, GN2000 Stereo, USB NC, GN2000 USB, GN2000 USB CIPC DUO, GN2000 USB CIPC MONO, GN2000 USB Duo MS OC, GN2000 USB Duo UC, GN2000 USB Mono MS OC, GN2000 USB Mono NC. MS OC, GN2000 USB Mono UC, GN2000 USB NC Microsoft Office Communicator 2007 , Jabra BIZ 2400 3in1 WB Balance, 2400 Duo, 2400 Duo IP, 2400 Duo USB, 2400 Duo USB OC, 2400 Duo WB Balance, 2400 Mono Headband, 2400 Mono IP 3-in-1, 2400 Mono, 3-in-1, 2400 MS USB Mono, 2400 USB Mono
Connectivity: Wired
Earcover : [N/A]
Brand: Jabra
