Jabra Handset 450 - White
Quicklinx: CJZ8WS00 Mfr#: 990-012-04
Handset 450 integrates wideband audio to give you a crystal clear and natural sound experience, guaranteeing that you won't miss any details.
Jabra Handset 450 for Cisco combines the comfort of a wireless phone experience with the many advantages of a UC solution. Offering plug-and-play installation, superior audio quality and remote call control, the wireless Jabra Handset 450 for Cisco is the perfect complement to Cisco Jabber for Virtual Environments. Fully integrated to support the softphone's call control features remotely, it lets you choose the way you want to work!
  • Crystal-clear sound
    Handset 450 integrates wideband audio to give you a crystal-clear and natural sound experience, guaranteeing that you won't miss any details. The noise-cancelling microphone will eliminate any background noise and ensure that you are always heard.
  • Wireless, secure and simple
    Jabra Handset 450's plug-and-play solution ensures that installation is truly hassle-free. Wireless DECT technology allows you take the call anywhere in the office, with up to a 20 m range. High security DECT encryption and physical pairing, (rather than over the air) safeguards superior transmission security.
  • You're in control
    Several Handset 450 features enhance user convenience, allowing you to have firm control. Lift the handset to answer a call. Put it back in the cradle to end it. Easy controls allow you to mute calls and adjust volume. A beep tone will let you know if there is a call waiting. The rechargeable battery gives you up to 15 hours of talk-time.
  • Supported platforms
    Works with most softphones such as Skype for Business (Lync) and is certified for Cisco Jabber .
Jabra 450 - VoIP handset
VoIP handset - wireless
White
Wireless
Microphone Operation Mode
Omni-directional
Controls
Mute, volume
Dimensions & Weight Details
Handset: 4.4 cm x 20.3 cm x 4.7 cm / 185 g , Cradle: 5.7 cm x 21.1 cm x 3.6 cm / 175 g
5.7 cm
21.1 cm
6 cm
360 g
White
Max Operating Distance
20 m
Audio Output
Wireless
Diaphragm
28 mm
Microphone
Omni-directional
Remote Control
Controls
Mute, volume
Wireless Link
Transmission Range
20 m
Connector Type
USB (4 PIN USB Type A)
Cradle
Cable Details
USB cable
Handset battery rechargeable
Run Time (Up To)
14 hour(s)
Standby Time
120 hours
Recharge Time
3 hour(s)
