Your calls. Your music. One headset. For work. For play. One headset.
Switch seamlessly between calls and music.
Great calls and sound
With 6.5 hours of music and talk time, the in-ear headphones isolate surrounding noise so you can hear all the details of your call and listen to every beat of your music. -
Great calls the easy way
Jabra Halo Fusion, the Bluetooth headphones that seamlessly switch between calls and music. With simple one-touch control and a comfortable wearing style, Halo Fusion provides a lightweight and convenient solution for those who like to easily access calls and music when on the go. -
Light and convenient
Relish in the convenience of a neckband that gives you easy access to your headphones throughout the day. The easy-to-reach headphones allow you to quickly insert and remove each earbud while your phone stays in your pocket. At just 21 g (0.7 oz), you won't feel the need to take your headphones off. -
Switch between calls and music with one touch
Jabra Halo Fusion allows you to control your calls and music directly from your headphones with one-touch controls, without ever needing to reach for your phone in your pocket. Switching between calls and music has never been so seamlessly easy – switch with one touch only.
- Jabra HALO FUSION - headset
- Product Type
- Headset - Bluetooth - wireless
- Recommended Use
- Portable electronics
- Additional Functions
- USB charging port
- Headphones Form Factor
- In-ear
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Headphones Technology
- Dynamic
- Bluetooth Version
- Bluetooth 4.0
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 98 dB
- Impedance
- 16 Ohm
- Max Input Power
- 10 mW
- Noise Isolating
- Controls
- Volume control, play/pause button, answer/end, next/previous track
- 1-year warranty
- Product Type
- USB charging port
- 13.605 cm
- 1.1 cm
- 15.56 cm
- 21 g
- Body Material
- Silicone, TPE, PC/ABS
- Recommended Use
- Max Operating Distance
- 10 m
Audio Output
- In-ear
- Dynamic
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 4.0
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Sound Output Mode
- Stereo
- Noise Isolating
- 20 - 20000 Hz
- Max Input Power
- 10 mW
- Sensitivity
- 98 dB
- Impedance
- 16 Ohm
- Diaphragm
- 9 mm
Microphone
- Sensitivity
- -42 dB
- 100 - 8000 Hz
- Audio Input Details
- Omni-directional
Remote Control
- Controls
Wireless Link
- Transmission Range
- 10 m
- Included Accessories
- 2 pairs of ear tips (small, large)
- Cable Details
- USB charge cable - 30 cm
- Battery
- Headset battery rechargeable
- Run Time (Up To)
- 6.5 hour(s)
- Standby Time
- 456 hours
- Recharge Time
- 2 hour(s)
- Limited warranty - 1 year
