Jabra GN2000 Duo USB NC Headset (Certified for Cisco)
Quicklinx: 7BKBWS00 Mfr#: 20001-496
The Jabra GN2000 CIPC headset enhances the user experience with the Cisco IP Communicator softphone by providing intuitive inline call control and crystal clear audio, even in noisy work environments.
The headset is certified for CIPC, meaning you can simply plug-and-play with your unified communications voice client. Just plug it into the USB port and you're ready to go. CIPC will automatically recognize the device, and you can answer/end calls and adjust volume levels via integrated inline control buttons on the cord.
The Jabra GN2000 CIPC headset series raises expectations of a professional grade headset in terms of durability, comfort and quality.
While most "wideband" headsets cut-off around 4,000 Hz, the Jabra GN2000 CIPC provides a full frequency response up to 6,800 Hz. This reduces misunderstandings and communication difficulties.
The headset features a noise-canceling microphone to combat background noise and PeakStop technology that protects the users hearing by cutting off sudden loud noises.
  • Plug-and-play with CIPC, no drivers needed
  • Wideband audio quality for clearer calls
  • Noise-canceling microphone
  • Duo stereo speakers
  • Enhanced user experience - ease of use
    The Jabra GN2000 CIPC headset enhances the user experience with the Cisco IP Communicator softphone by providing intuitive inline call control and crystal clear audio, even in noisy work environments. The headset is certified for CIPC, meaning you can simply plug-and-play with your unified communications voice client. Just plug it into the USB port and you're ready to go. CIPC will automatically recognize the device, and you can answer/end calls and adjust volume levels via integrated inline control buttons on the cord.
  • VOIP with superior call clarity
    The Jabra GN2000 CIPC headset series raises expectations of a professional grade headset in terms of durability, comfort and quality. While most "wideband" headsets cut-off around 4,000 Hz, the Jabra GN2000 CIPC provides a full frequency response up to 6,800 Hz. This reduces misunderstandings and communication difficulties. The headset features a noise-canceling microphone to combat background noise and PeakStop technology that protects the users hearing by cutting off sudden loud noises.
Jabra GN2000 USB CIPC DUO - headset
Headset - wired
Recommended Use
Computer
Headphones Form Factor
On-ear binaural
Wired
Headphones Technology
Dynamic
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 150 - 6800 Hz
Microphone
Boom
Microphone Operation Mode
Mono
Controls
Volume
Headset - wired
Recommended Use
Computer
Audio Output
On-ear binaural
Dynamic
Wired
Sound Output Mode
Stereo
Frequency Response
150 - 6800 Hz
In-Cord Volume Control
Microphone
Boom
Mono
Remote Control
Controls
Volume
Connector Type
USB (4 PIN USB Type A)
Cable Details
USB cable
Resources
The following resources are available for the Jabra GN2000 Duo USB NC Headset (Certified for Cisco)
