The EVOLVE Link unit can be matched with your existing EVOLVE headset. This version of EVOLVE Link is optimized for unified communication.
Digital signal processing
Digital signal processing is a technology that digitally optimizes your voice and music and suppresses echoes. -
Noise cancel
Enhances call clarity by eliminating background noise from the office. -
Mute function
Mute gives you the option to mute/unmute the microphone directly on the device. -
Jabra PC suite
Jabra PC suite enables remote call control with Jabra headsets and the generation of UC and IP softphones. Wireless headset users can answer and end calls away from their desk and softphone. With a corded headset, Jabra PC suite gives you a number of remote call control functions either directly from your headset or from in-line buttons on the cord. The seamless integration between headset and softphone allows users to benefit from enhanced mobility and the ability to multitask while on a call. This freedom improves work efficiency and ergonomics throughout the day.
- JABRA EVOLVE Link UC remote control
- Remote control
- Connectivity Technology
- Cable
- Supported Devices
- Headphones / headsets
- Designed For
- Evolve 40 UC mono, 40 UC stereo, 80 UC stereo
- Remote control
- Cable
- Supported Devices
- Volume control
- Connector Type
- 1 x USB
- Designed For
- Jabra Evolve 40 UC mono, 40 UC stereo, 80 UC stereo
