Your basket is empty
Jabra Evolve 80 MS Duo USB Headset
Quicklinx: 9TC5WS00 Mfr#: 7899-823-109
Recommended Use: Portable electronics
Connectivity: Wired
Earcover : Binaural
29 in stock
£188.98 ex VAT
£226.77 inc VAT
Express delivery Order within the next 11 hours for delivery tomorrow
The Jabra Evolve 80 MS stereo is a professional headset designed to improve concentration and conversations. Premium active noise cancellation technology gives you peace to work in a noisy, open office; effectively creating a concentration zone around you so you can stay focused.
Premium sound experience. Active noise cancellation technology and large around the ear cups designed to reduce unwanted noise. USB adapter with 3.5mm jack incorporated into the control unit allows you to easily connect your headset to your PC, smartphone and tablet. Busy light signals user availability. Microphone boom arm can be integrated into the headband when not on a call or simply listening to music. Microphone mute on boom arm. Built for style and comfort with leatherette ear cushions. Built for style and comfort with leatherette ear cushions. Soft pouch included. Listen in feature.
Jabra Evolve 80 MS stereo - headset
Headset - wired
Recommended Use
Portable electronics, conference
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Stereo
Microphone
Boom
Controls
Mute, volume, answer/end
Headset
Recommended Use
Headphones
Supraaural
Wired
Available Microphone
Sound Output Mode
Stereo
In-Cord Volume Control
Microphone
Boom
Remote Control
Headset remote control
Controls
Connector Type
Headset (4 PIN USB Type A) , Headset (mini-phone stereo 3.5 mm 4-pole)
Headset cable
Carrying pouch
Connectivity: Wired
Earcover : Binaural
Brand: Jabra
Price Range Ex VAT: 150 - 300
