Jabra Evolve 80 Duo UC USB Headset
Quicklinx: 9TC6WS00 Mfr#: 7899-829-209
Recommended Use: Computer, Portable electronics
Connectivity: Wired
Earcover : Binaural
40 in stock
£213.98 ex VAT
£256.77 inc VAT
MORE THAN HEADSETS, A WORKPLACE EVOLUTION
Jabra Evolve 80 is a professional headset that eliminates noise and helps you get in your concentration zone and focus. With smartphone connectivity you can take your concentration zone wherever you are going; work, at the office, at home, travelling or commuting. For calls or simply enjoying music.
UNRIVALLED NOISE CANCELLATION
Built to eliminate noise, Jabra's unique Active Noise Cancellation (ANC) filters out low-frequency background noise. Unique designed ear cushions block high-frequency sounds so you can enjoy your music or phone calls without distraction. Noise-cancelling microphone makes sure that you and the other party can hear each other loud and clear.
SIMPLE PLUG-AND-PLAY SETUP
Works straight out of the box with all leading UC systems. Installation is as easy as simply plugging it Into the USB port or 3.5mm jack to your laptop, or by using the 3.5mm jack straight into your smart device.
INTUITIVE CONTROL UNIT
Get easy access at your fingertips to the most used functions, like accept call, volume and mute.
SIGNAL YOUR AVAILABILITY
Whether you are on a call or working on a task needing your full attention, the Jabra EVOLVEā„¢ 80 has an integrated busy light on the ear cups, letting people around you clearly see your availability. You can activate the red busy light to create your own concentration zone and keep you from being disturbed whenever equired. Evolve 80 makes a great travelling companion too in noisy airports and public environments for phone calls or for music and relaxation. You can take your concentration zone wherever you need to go.
  • More concentration, greater productivity
    Shield disruptive background noise with superior active and passive noise-cancellation for crystal-clear calls and music.
  • Stay in the zone and avoid interruptions
    Superior ANC and an integrated busylight that notifies colleagues to avoid interruptions.
  • Find inspiration in sound
    Immersive music experience delivered by world-class speakers in a premium around-the-ear headset.
  • All-day comfort
    Leather-feel ear cushions and around-the-ear design for all-day use.
Jabra Evolve 80 UC stereo - headset
Headset - wired - 3.5 mm jack
Recommended Use
Portable electronics, computer - communication
Headphones Form Factor
Full size
Foldable
Wired
Headphones Technology
Dynamic
Sound Output Mode
Stereo
Sound Effects
PureSound
Audio Specifications
Frequency Response 20 - 20000 Hz
Max Input Power
30 mW
Active Noise Canceling
Microphone
Boom
Controls
Mute, volume, answer/end
Dimensions & Weight Details
Headset: 19 cm 19 cm / 324 g , Control unit: 5.5 cm 5.5 cm / 57 g
19 cm
19 cm
324 g
Earpad Material
Leatherette
Recommended Use
Headphones
Full size
Foldable
Dynamic
Wired
Sound Output Mode
Stereo
Sound Effects
PureSound
Active Noise Cancelling Technology
Hybrid ANC
Frequency Response
20 - 20000 Hz
Max Input Power
30 mW
Diaphragm
40 mm
In-Cord Volume Control
Busy light, Listen-in function
Microphone
Boom
Headset microphone
Remote Control
Controls
Connector Type
Headset (mini-phone stereo 3.5 mm 4-pole)
Cable
Cable Length
1.2 m
Carrying pouch, cord management clips
Cable Details
Headset cable - 1.2 m , USB control cable - detachable - 95 cm
Plug and Play, UL, FCC, KCC, RCM
Headset battery rechargeable
Recharge Time
2 hour(s)
Shipping Width
21.5 cm
Shipping Depth
21.5 cm
Shipping Height
5.5 cm
Shipping Weight
646 g
Recommended Use: Portable electronics
Connectivity: Wired
Earcover : Binaural
Brand: Jabra
Price Range Ex VAT: 150 - 300
