Engineered to be the world's first professional UC-certified wireless earbuds, the Jabra Evolve 75e combines Skype for Business certification, incredible Active Noise Cancellation, a host of professional features found in the Jabra Evolve series, and a wearing style popular with mobile office workers.
The Evolve 75e fully charges in just two hours, and the best-in-class battery provides up to 14 hours of power. Five control buttons provide easy access to calls and music, and include a smart button for one-touch access to Siri® and Google Now™. All-day comfort is provided with multiple fittings for gels and earwings.
Professional Sound. The way you want to wear it.
UC certified three microphone technology creates a unique talk-zone, and with an around-the-neck, wireless earbud design.
Powerful at work. Fully concentrate whatever the noise around you.
Focus with Active Noise Cancellation, and an integrated busy-light lets colleagues know you are not to be disturbed.
Last as long as you need it. All day long.
Enjoy up to 14 hours of battery life on just a single charge - and fully charge the earbuds in just 2 hours.
Professional sound
Skype-certified 3-microphone technology creates a unique talk zone, making sure you're heard, while other nearby voices are filtered out. With an around-the-neck, wireless earbud design. -
Powerful at work
Focus with Active Noise-Cancellation and an integrated busylight lets colleagues know you are not to be disturbed. -
Calls and music that last for as long as you need them to
The Evolve 75e fully charges in just two hours and that best-in-class charge provides up to 14 hours of battery life. -
Multiple fitting options
Personalised fit for an improved experience. Multiple fitting options for EarGels and EarWings give amazing comfort throughout the day. -
Smart controls for work and play
Five buttons for quick control of calls and music, including a smart button for one-touch access to Siri and Google Now and a vibrating neckband to provide silent notifications.
- Jabra Evolve 75e UC - earphones with mic
- Product Type
- Earphones - Bluetooth - wireless - USB
- Recommended Use
- Portable electronics, computer - communication
- Headphones Form Factor
- In-ear - behind-the-neck mount
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Headphones Technology
- Dynamic
- Bluetooth Version
- Bluetooth 4.2
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz
- Active Noise Canceling
- Noise Isolating
- Microphone
- On-cable
- Microphones Included
- 3
- Controls
- Volume, answer/end, play/pause, next/previous track, reject call
- 2-year warranty
- Product Type
- 17.6 cm
- 18.6 cm
- 5.4 cm
- 50 g
- Body Material
- Silicone
- Recommended Use
- Vibrating call alert
- Protection
- Waterproof, sweat-resistant, IP54
- Max Operating Distance
- 30 m
Audio Output
- Dynamic
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 4.2
- Sound Output Mode
- Stereo
- Noise Isolating
- Active Noise Cancelling Technology
- Hybrid ANC
- 20 - 20000 Hz
- Diaphragm
- 15 mm
- In-Cord Volume Control
- Simultaneously Connectable Devices Qty
- 2
- Voice guidance, magnetic ear buds, Busy light, Jabra Direct
Microphone
- On-cable
- 3
- 150 - 6800 Hz
Remote Control
- Controls
- Connector Type
- USB (power only)
- Included Accessories
- Protective case, leaflet, Jabra Link 370 USB Adapter, EarGels and EarWings pack (S/L size)
- Cable Details
- USB cable - 1.5 m
- Battery
- Headphone battery rechargeable
- Run Time (Up To)
- 14 hour(s)
- Recharge Time
- 2 hour(s)
- Limited warranty - 2 years
