Jabra Evolve 75 Stereo MS Wireless Headset
CASHBACK AVAILABLE!
Cashback
Quicklinx: CWNPWS00 Mfr#: 7599-832-109
Recommended Use: Computer, Portable electronics
Connectivity: Wireless
More than 50 in stock
£159.91 ex VAT
£191.89 inc VAT
The best wireless headset for concentration in the open office
Block out noise and interruptions in the open office and stay focused on your tasks. Our professional wireless headset delivers amazing sound and superior Active Noise Cancellation.
The Evolve 75 is a wireless headset with superior Active Noise Cancellation and integrated busylight to enhance your productivity. Dual connectivity to two Bluetooth® devices allows you to take calls and listen to music from the same headset, giving you extra freedom to move 100ft/30m away from your smartphone and/or PC.
Outstanding sound for calls and music
HD voice for your calls and world class speakers for music.
Reduce noise and interruptions
Superior ANC and integrated busylight acting as a do not disturb signal
More freedom
Dual Bluetooth® connectivity to two devices at the same time for calls and music, with the flexibility to move up to 100feet/30 meters away from your connected device.
Wireless Bluetooth technology gives you up to 30 meters / 100 feet of hands-free connectivity to PC, smartphone and tablet. Up to 10 hours battery life eliminates battery concerns. Simply tap to connect devices with NFC. Dual connectivity enables you to connect your headset to your PC and one other Bluetooth device at the same time, so you can take the call on your preferred phone device. Busy light signals user availability. The microphone boom arm can be integrated into the headband when not on a call. Microphone mute on boom arm. Built for style and comfort with leatherette ear cushions. Soft pouch included.
  • Outstanding sound for calls and music
    World-class speakers and HD voice for crystal-clear calls and music.
  • Reduce noise and interruptions
    Superior ANC and integrated busylight acts as a 'do not disturb' sign to enhance productivity.
  • More freedom
    Dual Bluetooth connectivity to two devices at the same time for calls and music. Flexibility to move up to 100ft/30m away from your connected device.
Jabra Evolve 75 MS Stereo - headset
Headset - Bluetooth - wireless - USB
Recommended Use
Portable electronics, computer - communication
Headphones Form Factor
On-ear
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.2
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz
Active Noise Canceling
Microphone
Boom
Microphone Active Noise Cancelling
Microphones Included
4
Controls
Mute, volume, on/off, answer/end
Software Certification
Certified for Skype for Business
177 g
Recommended Use
Max Operating Distance
30 m
Audio Output
On-ear
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.2
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio Gateway Hands-Free Profile (AGHFP)
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
Diaphragm
40 mm
In-Cord Volume Control
Simultaneously Connectable Devices Qty
2
Busy light
Microphone
Boom
Headset microphone
4
Frequency Response
100 - 10000 Hz
Signal-to-Noise Ratio
17 dB
Audio Input Details
Uni-directional - 100 - 10000 Hz
Remote Control
Controls
Connector Type
Headset (4 PIN USB Type A)
Protective case, Jabra Link 370 USB Adapter
Cable Details
USB cable - detachable
Headset battery rechargeable
Run Time (Up To)
18 hour(s)
Standby Time
360 hours
Recharge Time
2 hour(s)
CWNP Jabra USB-A to USB-C Adapter In Stock £7.73
Resources
The following resources are available for the Jabra Evolve 75 Stereo MS Wireless Headset
Recommended Use: Portable electronics
Brand: Jabra
Price Range Ex VAT: 150 - 300
