Jabra Evolve 75 SE Stereo Bluetooth Wireless Headset
Quicklinx: H1SQWS00 Mfr#: 7599-842-109
The Evolve 75 is a wireless headset with superior active noise-cancellation and integrated busylight to enhance your productivity. Dual connectivity to two Bluetooth devices allows you to take calls and listen to music from the same headset, giving you extra freedom to move 30m away from your smartphone and/or PC.
Jabra Evolve 75 SE MS Stereo - headset
Headset - Bluetooth - wireless - USB
Recommended Use
Portable electronics, computer - communication
Headphones Form Factor
On-ear
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.2
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 117 dB
Max Input Power
30 mW
Active Noise Canceling
Microphone
Boom
Microphone Operation Mode
Uni-directional
Microphone Noise Cancelling
Microphones Included
3
Controls
Mute, volume, answer/end, busylight, on/off, ANC on/off, status indicator
Software Certification
Certified for Microsoft Teams
LINK 380a MS
15.5 cm
6.45 cm
18.45 cm
177 g
Headband Material
Foam, silicone
Earpad Material
Leatherette
Recommended Use
Max Operating Distance
30 m
Audio Output
On-ear
Wireless
Wireless Technology
Bluetooth
Bluetooth Audio Codec
SBC
Bluetooth Version
Bluetooth 4.2
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP), Hands-Free Profile (HFP), Headset Profile (HSP), Audio Gateway Hands-Free Profile (AGHFP)
Sound Output Mode
Stereo
Active Noise Cancelling Technology
Hybrid ANC
Frequency Response
20 - 20000 Hz
Max Input Power
30 mW
Sensitivity
117 dB
Simultaneously Connectable Devices Qty
2
Busy light, SafeTone technology, Jabra Direct, Jabra Xpress
Microphone
Boom
Headset microphone
Uni-directional
3
Sensitivity
-17 dBFS/Pa
Frequency Response
100 - 10000 Hz
Signal-to-Noise Ratio
17 dB
Noise Cancelling
Audio Input Details
Uni-directional - 100 - 10000 Hz
Remote Control
Controls
Connector Type
Headset (4 PIN USB Type A)
Jabra Link 370 USB Adapter, protective case
Cable Details
USB cable - detachable
FCC-ID, KCC, NCC, RCM, SRRC, TELEC, IC
Headset battery rechargeable
Run Time (Up To)
18 hour(s)
Run Time Details
Continuous talk: up to 18 hours , Continuous playback: up to 17 hours
Standby Time
15 days
Recharge Time
2 hour(s)
Shipping Width
18.1 cm
Shipping Depth
21 cm
Shipping Height
5.3 cm
Jabra LINK 380a MS
