The Jabra Evolve 65e is engineered to deliver professional, UC-certified sound on the go. The around-the-neck earbud design allows you to take calls and listen to music, while Skype for Business and UC certification mean your headset will provide consistently superior sound on the go. The battery will last up to 13 hours, and the USB Bluetooth adapter allows you to connect to your laptop or PC, as well as your smartphone. Customise your sound and update software with the Jabra Sound+ app, and signal when you’re busy with a built-in busylight.
All-day comfort
When you need to be available for calls any time, you need a headset that is comfortable enough to wear all day. The Evolve 65e features a convenient, lightweight, around-the-neck design with snug-fitting oval earbuds. This design provides maximum comfort and ease of use, so you can answer calls and listen to music all day; wherever you are, whatever you’re doing. -
Professional UC-certified earbuds
The Evolve 65e is Skype for Business and UC certified, so you can use it for all your important calls in total confidence. This headset provides consistently superior sound and call quality, especially whilst you are outside the office, so you don’t need to worry about wind noise or poor connection. With the USB Bluetooth adapter, you can also connect to your PC at the same time as your smartphone. -
Stay productive on the go
Stay productive on the go, with a battery that’s built to go the distance, giving you up to 13 hours of charge. Wherever you need to be, whatever you need to get done, you can be sure that your headset will be able to keep up. -
Great music when you want it
Jabra-engineered speakers ensure that your music sounds exactly as it should, while a snug, in-ear fit provides passive noise cancellation, filtering out background noise to help you concentrate on what you’re doing. A built-in busylight acts as a ‘do not disturb’ sign, signalling to those around you when you’re not to be interrupted.
- Jabra Evolve 65e MS - earphones with mic
- Product Type
- Earphones - Bluetooth - wireless - USB
- Recommended Use
- Portable electronics, computer - communication
- Headphones Form Factor
- In-ear - behind-the-neck mount
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 4.2
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz
- Noise Isolating
- Microphone
- On-cable
- Microphones Included
- 4
- Controls
- Volume, answer/end, play/pause, next/previous track, reject call
- 2-year warranty
- Product Type
- 15.3 cm
- 19.2 cm
- 6.3 cm
- 36 g
- Body Material
- Silicone
- Recommended Use
- Vibrating call alert
- Protection
- Waterproof, sweat-resistant, IP54
- Max Operating Distance
- 30 m
Audio Output
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 4.2
- Sound Output Mode
- Stereo
- Noise Isolating
- 20 - 20000 Hz
- Diaphragm
- 12 mm
- In-Cord Volume Control
- Simultaneously Connectable Devices Qty
- 2
- Busy light
Microphone
- On-cable
- 4
Remote Control
- Controls
- Connector Type
- USB (power only)
- Included Accessories
- Protective case, leaflet, Jabra Link 370 USB Adapter, EarGels and EarWings pack (S/M/L size)
- Cable Details
- USB cable - 1.5 m
- Battery
- Headphone battery rechargeable
- Run Time (Up To)
- 13 hour(s)
- Recharge Time
- 2 hour(s)
- Limited warranty - 2 years
